Home > Show Us Yours! > Ooooo now this is interesting!!
On 19th Nov, 2008 robert said:
On 19th Nov, 2008 Sprocket said:
the hloe was a mistake, as it started to cut into or far too close to the tiebar location?
well done colin !!!!
not quite sure what a ''hloe'' is mind you ,but im assuming you mean ''hole''
yep like a numpty i was alll carried away with my hole cutter and thought hey theres a handy hole for the pilot drill and off i go ,then looked behind and thought um NO ,,,,NO MORE and then welded it back up. :-
the hloe is a mistake:$ When im tired, the dyslexic filter doesnt work so well*frown*
ha ha ha!!!
That is CLASSIC!
I welded some heavy eyelets into a similar-ish area for holding the mini down on the rollers as the place I (now) go to has the straps in the perfect wrong place to be of any use. More weight of course!
I have MRA Minis towing eyes in the front panel mounts, no welding needed *tongue*
And you're happy to pull 'down' on these mounts? You're still putting a large bending on a 3/8UNF thread potentially.
I guess it's ok if using decent bolts though. I am however glad I didn't have the displeasure of giving MRA any money however - since they threatened to sue TurboPhil over his dizzy blanking plugs I changed my mind about that guy.
On 19th Nov, 2008 TurboDave said:
ha ha ha!!!
That is CLASSIC!
aye thank you .... hey , at least i didnt go through both sides just half the first one *happy**surprised*
Hmmm, just realised the thread of the 'designed and manufactured by MRA' front panel mounts is stainless, not high-tensile steel...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=350104233385
Nice, looks like you know how to work a hole saw! *hehe!*
So...whats the weight saving on the subby soo far? Oh yeah those bolts are the choice of champions. *wink*
I was speaking to the guy that does my welding, and he recons every 14lbs you save is the equivalent to 5bhp gained.
They have a load carrying capacity of 450kg each.
rollin ,,now wheres a railway track !!
looking promising !
so far i have mostly been doing cam profiles and head flow measurements ,its gone from 128 cfm to 142 so far with 5 minutes porting .more to come .
Wont be long before its spitting fire and making 13's on the strip :)
We'll have to lay some railway tracks down the strip first.
Good to see some progress, have you figured out how to route the exhaust?
I'm guessing it's going to go straight through that hole in the inner wing!
leroymornsey
Member #: 5265
telford
what got me was i work on taxis as my job and it really fecks me off when people start an engine up and nail the thottle with out warming up or letting oil circulate the block more so for turbos
garlic bread
gosh i knew there was something i forgot leroy . i hang my head in abject shame .
fortunately i pre lubed the turbo with a special lubricant kryophosphate yttrium gelly ,specially made for doing the job ,hopefully that will overcum the drawbacks of premature start up , and leave me with no undue wear problems .
Edited by robert on 8th Mar, 2009.
Ric
Member #: 36
Basingstoke
lmfao!!!!!!!!!!
everyday is a school day robert!
what the fuck is that turbo! its huge!
hahahaha
itss a hybrid joe ,k24 turbine ,and no one really knows what compressor ,er it may be a bit big ... i do know its b een run up to 42 psi on a 2.3 though !
Ahhhh! So thats what Robert wanted all those sleepers for a couple of years ago.......
Looking good!
Is that another engine you have there, or just a mock up?
hi nic , no thats the test engine before i take it all apart .
I was considering doing a similar thing with the exhaust manifold on a friends car. I was just a bit concerned about the pipework being so close to the bias valve. Do you think it will cook the fluid?
MadMatt
Member #: 105
Brisbane ,Australia
Ahhh,,, i see you like a little bit of mini with your turbo *wink*
& ar,,, er,,, um,,, melting slave cyl & brake valve any issue ? *smiley*
www.miniman.com.au
I reckon itll be ok, its not that close, and the bonnet lifted will help
Just as long as that turbo isnt restrictive and it all starts glowing eh??
zacto nic, we wouldnt want that would we *wink*
matt ,the engine is a bit leaning back from where it will be , and ill get rid of the valve and put an adjustable one inside probably .
interstingly , i can get the bonnet shut completely with the oil filler cap off ,no machining nor nuffin !
Good work Robert. Problem is if it continues at this pace, you'll have to decide which mini to bring to avon.
Are you making another special clutch for it?
