Home > 998cc > A little guidence for this winters project, please.
As far as I know there's no such thing as wastegate chatter, it'd some crap Clarkson spouts.
With no DV when you close the throttle the turbo continues to make boost.
All this pressure builds up until it stops the turbo dead.
This will cause the "drive shaft" inside the turbo to break.
Now your turbo is scrap! Possibly your engine tooif any broken bits from the turbo get swallowed.
As Gav states............
Waste gate chatter is the waste gate trying to deal with this situation, however it cannot do so effectively, so the turbo shaft goes from many thousand rpm to STOP! in a few microseconds, this does the shaft NO GOOD at all and if it continues to happen will fatigue the shaft until it breaks.
As the guys say that noise is turbo stall or whatever you like to call it,
there is allegedly a phenomonen called waste gate chirp, I've never come across it but it is suposed to be the sound made by the waste gate valve when the pressure in the exhaust manifold is enough to cause the wastegate to lift of its seat causing a kingd of squeek sound, abit like putting your finger over an airline.
shane
Member #: 1246
Lowestoft, Suffolk.
Thanks gents, thats cleared things up, any suggestions for a recirc system?
Shane.
something along the lines of this, just plumb the outlet back in before the turbo.
http://cgi.ebay.co.uk/SUBARU-IMPREZA-DUMP-...1QQcmdZViewItem
Most production turbo cars have recirc DV's. Cossies and Saabs spring to mind, may find something down the scrap yard?
shane
Member #: 1246
Lowestoft, Suffolk.
When you say most? I cant remember seeing one on my old 5GT? But in all honesty never really went looking, how do production turbod cars that dont have them fair without?
Thanks
Shane.
shane
Member #: 1246
Lowestoft, Suffolk.
sorry, double post.
Shane
Edited by shane on 30th May, 2007.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Most MODERN turbo production cars.
VW / Audi 1.8T use the same Bosch recirc valve as SAAB etc. .... onther option.
