| Home > Help Needed / General Tech Chat > Anyone Know how this connects up? | |||||||
12th Jun, 2007 at 01:34:57pm
67.932 degrees C
12th Jun, 2007 at 02:04:37pm
i shall get my surface probe out when i get home!
12th Jun, 2007 at 04:03:24pm
well, mine was new from 1071s, and after about 10 mins of running, it was hot to the touch, I guess around 50 - 60 degress. is that normal? Team www.sheepspeed.com Racing
12th Jun, 2007 at 05:14:11pm
I wouldnt have thought so Jim, Ive never felt any heat off an alternator personally, no matter how hard Ive been driving.
I seriously doubt it! |
12th Jun, 2007 at 06:43:58pm
I'm guessing that the pulley is too small, but at the time I was only idleing, so shouldn't have been a problem Team www.sheepspeed.com Racing
13th Jun, 2007 at 07:33:39am
if you've got a std crank pulley it would have to be fooking small to worry an alternator...
13th Jun, 2007 at 07:51:54am
Edited by Bat on 13th Jun, 2007. VEMs Authorised Installer / Re-seller. K head kits now available!
13th Jun, 2007 at 10:59:39am
There is an alternator recon place where you used to have your unit don't forget who will be able to confirm it one way or the other Paul On 5th Sep, 2011 Vegard said:
13th Jun, 2007 at 11:00:58am
yea, I have the std crank pulley, I don't have a fan on the battery at the moment, but the battery was very flat, so it would be taking a good charge. Team www.sheepspeed.com Racing
13th Jun, 2007 at 05:33:56pm
13th Jun, 2007 at 05:35:10pm
Mine gets Warm to touch when it is used, I thought i had wrecked it, But i have put the meter accross the battery and its charging fine. I also tried to fit a small kubota type alternator but it stuck out from the block further than the larger cased swift type alternator on my aplication! |
13th Jun, 2007 at 09:10:20pm
On 13th of Jun, 2007 at 07:51am Bat said:
Hi, Do you know what output (Amps wise) the alternator is. Cheers, Gavin :) Mine is 40 amp. My standard one was 45amp. Paul I seriously doubt it! |
14th Jun, 2007 at 08:51:21am
14th Jun, 2007 at 09:26:13pm
No not yet, I will be in the next week or so.
24th Jun, 2007 at 08:57:06am
OK Ive connected it up now and the lights work atleast, but havent run the engine yet as Im still fitting the new exhaust.
30th Jun, 2007 at 03:59:04pm
Bat, all seems to be good. Ign light works as it should and it charges well.
