Home > Show Us Yours! > at last the gear box has exploded nicely !!:(
clubminiflip
Member #: 54
nr coventry
oh thats a a right bag "o" spanners is'nt it, is that scoring on the layshaft, the case on its own will need a blumming good clean up if its not damaged!
are those marks in the oil pickup pipe frm bits flying about when it went pop!
i feel your pain on this one robert!
when it comes to mini gearbox's a bit of over-engineering could be used, but as they also say, bring it back harder,better,faster&stronger robert!
Jason G
Member #: 1459
En-suite user
Braintree, Essex
New & improved is called for robert
On 19th Jan, 2010 wil_h said:
Yep thats buggered!
I'm sure this is akin to teaching granny to suck eggs Robert, but if I were you I'd pull the engine gallery plugs and give it all a good clean out just in case some bits of that lot got where they shouldn't have.....
Anton
Member #: 764
Staffordshire
fook well done....
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Phwar, all the gears have swapped teeth!
On 7th Nov, 2008 Nic said:
naeJ
m
Im impressed how quickly you've stripped it down...if it were me I would of spent at least a few weeks tyre kicking before getting the motivation to strip down! :)
On 30th of Jul, 2007 at 08:49am wil_h said:
Oh dear.
I wonder what has actually broken? Obviously all the teeth didn't fall off at the same time. Maybe the layshaft has snapped, or a bearing gone???
nope wil all the shafts and bearing seem in very good condition ,no scoring or wear showing .quite amazing really.
On 30th of Jul, 2007 at 05:37pm matty said:
OOO you've done well mate!!!
Do you think it could something to do with when you changed your diff? I would of though alot more strain would be put on the 'box running a 2.9 diff, could of tipped it over the edge?? *oh well*
Hope you get it sorted..especially with MITP just around the corner!!
Ive got a standard 'box here if you need any spare bits?
thanks matty , i may take you up on that ill see what i have in the shed , i do agree that the 3rd gear with a 2.95 diff seems to have a much greater exposure to loads of torque as it pulls in that gear for a whilev , i may use this as a chance to go back to a 3.1 ,and run bigger wheels on the rd .
yes dave those are marks from the bits , the underside of no 1 piston is a bit peppered along with the rod !!thats with the engine stopping dead when it happend.
On 30th of Jul, 2007 at 07:07pm Tom Fenton said:
Yep thats buggered!
yes tom your prob right .
Oh dear.
Amazing. I've never seen that before.
Turbo Shed
Member #: 30
Epsom, Surrey
nice light weight gears, you should sell them on ebay
but more picturnosity..
shafts look ok , gear wheels need a bit of work ,thought i might weld the teeth back on ?
im guessing from the state of the umpteen other teeth in the case that 1st motion gear spat a tooth ,that fell in the gears and started stripping them and this locked against the wheels and stripped 3rd gear ,maybe perhaps .
im happy to confirm that a stock turbo helical box will break if it has 150 lbs ft put through it.
Turbo Shed
Member #: 30
Epsom, Surrey
nice
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
I think Candice's engine build has just lost a couple of psi in boost .... lol
I'd be fairly sure that its use at Avon would be the underlying cause....
Sorry to hear that mate, thanks for showing use the great pictures of the massive damage.
I'm surprised it lasted you this long mate after seeing how good your car was at Avon!
I hope you sort it soon.
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
Did i just read you right saying you might weld the teeth back on or were you taking the mick?
If you were serious........GET A GRIP!!! LOL
danboy
Member #: 1381
Minimadj, You have obviously not heard of molecular welding. Briefly it's a system for joining broken parts where the break is totally clean. The parts are clamped together tightly and an ultra high frequency is passed through the parts. At the interface of the break extreme heat is generated which restores the molecular structure to around 98% integrity. It's a system developed by NASA for use in future space stations but is now finding it's way onto Nuclear subs and ocean going tankers where new parts are hard to find.
I don't know how Robert has access to this technology as it's just one step below Top secret.
Perhaps he would care to tell us.
Regards
Dave
Jordan
Member #: 1392
Ah ive got one of them dave.
20 quid from costco.
Not bad eh? :p
TBH i thought that only worked on plastics.
Looks like Robert has a jigsaw more complex than jenga to rebuild
danboy
Member #: 1381
Not bad eh? :p
It used to!! Things have moved on a long way from HF welders on plastics. In fact I had one it cost a fortune and never worked consistently.
Looking forward to seeing Roberts box repaired.
Regards
Dave
happend to me robert :( many moons ago
go SC at least you get the ratios you know you want *wink**wink**wink*
Oh! dont forget the drops as well
this is what has caused the problem
tell me more obi one !*smiley*
im having enough trouble saving up for the box gears yet alone drops as wel!!. i ws rather hoping all that stuff on mini spares about the drops being just as strong in heli was a bit that kieth actually got right !lol
incidentaly if anyone has this happen to them ,and your not sure what it sounds like ,.. imagine ..take a tin chocky biscuit box ,put in 6, 6 inch nails ,and 2, steel boul balls like they use in france , then put the lid back on ,then,, get a friend to climb up a 3 story building and throw it off the top ...
the sound it makes when it hits the ground is what your listening for .
