Home > Technical Chat > Tuning metro turbo engine
Being as the standard actuator normally runs at 7psi through a controlled bleed valve, a bleed valve seems the cheapest and best option to me.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
just what the others have said, just a good tune up at the local RR.
Edited by Jason G on 24th Mar, 2008.
On 19th Jan, 2010 wil_h said:
mg-metro-matt
Member #: 1870
Aldershot (we are top of the league, say we are...)
cheers milamber
have just bought this bleed valve:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...:MEWN:IT&ih=017
and am thinking about buying this dump valve
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...bayphotohosting
Seems abit pricey, but it comes with a fitting kit. Has anyone bought one of these before? if so is the fitting kit any good?
cheers
Edited by mg-metro-matt on 11th Mar, 2008.
I'd always avoid bleed valve wherever possible as what you bleed off could be going in the engine.
I'd go for the 8 psi or you could try winding up the pre-load on the standard one?
On 11th Mar, 2008 mg-metro-matt said:
On 11th Mar, 2008 Turbo Phil said:
You could try putting a little more preload on the actuator, you may get a little more boost.
Would i do this by winding the actuator bar in towards the acuator or out?
Shorten the actuator rod.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I thought that image on your sig looked familiar. Your right not selling (an not modding heavily), it's immaculate!
On 7th Nov, 2008 Nic said:
naeJ
m
mg-metro-matt
Member #: 1870
cheers jay, just ordering some bits of speed genie it lists a different carb needle for 8psi, would it be neccesary to change my carb needle from the standard one to run at 7 psi accross the whole rev range?
mg-metro-matt
Member #: 1870
right have ordered some bits up, have ordered a dump valve from avonbar with the carb spacer to plumb it in. Found this on ebay to fit the dump valve to:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...:MEWA:IT&ih=019
have ordered a exhaust system from maniflow.
thanks for all you help, i shall keep u all posted how i get on
Edited by mg-metro-matt on 13th Mar, 2008.
mg-metro-matt
Member #: 1870
sorry to keep asking questions but do you think i will need to change the spark plugs or carb needle to run at 7-8psi accross rev range?
plugs currently are BPR6ES
needle currently the standard one which is BDD
many thanks
Again, a rolling road would be the best solution to getting the needle right.
Plugs should be fine.
mg-metro-matt
Member #: 1870
Had a little tinker today, have fitted the single box maniflow system, which sounds the nuts. Also shortened the actuator bar which has increased the boost to 6.5psi then after 4000rpm the E.C.U operates the bleed valve still and increases it to 7.5psi.
Happy days!
Just gotta wait for the dump valve bits to arrive from Avonbar now.
mg-metro-matt
Member #: 1870
also got this little bad boy off ebay, which is gona save me cutting up my plenum chamber:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=290089630114
Standard plugs will be fine. I run 20psi with them in mine.
mg-metro-matt
Member #: 1870
BPR6ES's?
Yes. Though i know most other people have had to go colder, and as a rule you generally do on a tuned motor. But mine kept fouling the 7's when pottering round town etc. Changed to the 6's still with 20psi and it's been fine.
mg-metro-matt
Member #: 1870
think i shall stay with the 6's then, only running 7psi boost.
many thanks
mg-metro-matt
Member #: 1870
Hi all
Time for an update!
Ok the car is all standard apart from a maniflow performace system, k&n air filter element, original wastegate actuator adjusted to increase boost and a dump valve. I had it set-up by peter baldwin yesterday where he profiled the needle to allow more fuel at the top end and adjusted the ignition timing. It produced 131bhp at 6200rpm! not bad atall. The boost provided interesting reading (i still have the ecu connected), im showing 7psi of boost upto about 5000rpm then it gradually increases to about 10psi at 6200rpm. I assume this is the ecu bleed valve kicking in and rather than it being 4psi increased to 7psi, as i have adjusted the actuator to 7psi it now increases it to 10psi. any ideas?
cheers!
oh yeh, some footage from the rolling road:
http://www.youtube.com/watch?v=agM6noGhnj8
