| Home > Show Us Yours! > Jet black turbo, 15-5-08 Mmmmm shiney!! | |||||||
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
28th Mar, 2008 at 12:16:02am
On 27th Mar, 2008 shane said:
How tight? A nuns chuff? Got one of jasons heat shields here somewhere too, will give me an extra mm or 2 Shane Pretty much a nuns chuff yeah - my plenum had actually started tapping the bulkhead before I swapped to solid engine mounts! On 15th Jul, 2009 fastcarl said:
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
28th Mar, 2008 at 08:17:44am
I use std length steadies, std subby etc and its tight but fits.
28th Mar, 2008 at 10:09:22am
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
28th Mar, 2008 at 06:46:28pm
On 28th Mar, 2008 iain said:
I use std length steadies, std subby etc and its tight but fits. My downpipe had to be cut and shut a lot! i need to tidy it up when it comes out next month for a few bits of work. |
28th Mar, 2008 at 06:47:57pm
On 28th Mar, 2008 Bat said:
Hi, Try an MPi tie bar, should be a little bit longer might just do the job
Have you tried a N/A inlet manifold? Cheers, Gavin :) |
29th Mar, 2008 at 06:38:47pm
sorry mate no, because cut along the weld and add a bit more of a wedge out.
29th Mar, 2008 at 06:53:17pm
I started chopping the down pipe about last nite, decided to wait till my exhaust turns up, so Ive got a point to work to, but I have had the same thought to what you have just mentioned, so at least i know im on the right lines. You can see by how far the studs are out when the set in the down pipe is where it needs to be to clear the pot that there needs to be an adjustment to the elbow.
4th Apr, 2008 at 09:06:26pm
Progree has ground to a hault this week due to waiting for so many parts, some finally arrived so heres the update.
4th Apr, 2008 at 09:07:11pm
sorry Edited by shane on 4th Apr, 2008. |
4th Apr, 2008 at 09:19:48pm
ouch, nasty about the rad and poo about parts! im waiting on parts too, 2 weeks now :( over than that mate looks top notch!! |
4th Apr, 2008 at 09:26:19pm
If the rad and a few parts take their time and thats the worst that happens then im doin well. Just getting worried im running ut of time!
4th Apr, 2008 at 09:37:41pm
no way of repairing the rad? "Turbo's make torque, and torque makes fun"
4th Apr, 2008 at 09:42:03pm
I'm suprised yo managed to knacker the rad that easily, the tube are fairly sturdy. On 28th Aug, 2011 Kean said:
4th Apr, 2008 at 10:05:54pm
I wish there was, its well pierced, got stuffed by a raggy sharp edge, wouldnt mind if it had been used, lol
4th Apr, 2008 at 10:16:24pm
send it back and say it was damaged by the courier?... On 28th Aug, 2011 Kean said:
4th Apr, 2008 at 10:26:09pm
Lmao, now theres an idea, can imagine the conversation now, "can you explain Mr pearce why you have sent a radiator back that you purchased over a year ago and have had painted, claiming it was damaged by our currior?" Shame it wasnt that easy, I built the engine up last winter, and bought it then, shame, lol
8th Apr, 2008 at 09:49:29pm
Had the last two days off, and have spent the afternoons playing with the car, and progress is as follows.
8th Apr, 2008 at 10:36:36pm
Looking good.
On 4th Apr, 2008 shane said:
MJ cables nearly all in, just need to decide where the lives are coming from, and mount the edis etc. Run a feed direct from the battery (via a relay). Isambard Kingdom Brunel said:
8th Apr, 2008 at 10:44:12pm
On 8th Apr, 2008 Rob H said:
Looking good. On 4th Apr, 2008 shane said:
MJ cables nearly all in, just need to decide where the lives are coming from, and mount the edis etc. Run a feed direct from the battery (via a relay). |
![]() 157 Posts Member #: 1508 Advanced Member n ireland killyleagh |
8th Apr, 2008 at 10:45:15pm
looks great!!! minisport wouldn't hold your breath you'll still be holding it at the end of month waiting. I'm stupid Ive A fiesta with most of the bits to make my megajolt thingy. Thick or what!!!! OHHHHH and ive got a metro for free !!!!! Metros have become rare over here!!!!!!!!!
8th Apr, 2008 at 11:14:15pm
Cheers for filling me with confidence, lmao!
8th Apr, 2008 at 11:29:17pm
SORRY just i waited weeks for a clutch plate.And then for backing plates. Then they tryed to rob me with postage £27.00 said they would refund me some of it still waiting Sorry hope the pipe comes soon. I'm stupid Ive A fiesta with most of the bits to make my megajolt thingy. Thick or what!!!! OHHHHH and ive got a metro for free !!!!! Metros have become rare over here!!!!!!!!!
784 Posts Member #: 912 Post Whore North Yorkshire |
9th Apr, 2008 at 02:01:35pm
On 8th Apr, 2008 shane said:
Im just going to remove the ballest resistor wire from the ignition switch and take it off there, just got a few other little jobs to do before i can get on to that. Cheers Shane On 8th Apr, 2008 Rob H said: Looking good. On 4th Apr, 2008 shane said:
MJ cables nearly all in, just need to decide where the lives are coming from, and mount the edis etc. Run a feed direct from the battery (via a relay). I drill holes in everything..! |
Site Admin 6301 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
9th Apr, 2008 at 02:13:10pm
Only just spotted this thread - What a cool little mini. Mint! |
13th Apr, 2008 at 10:05:25pm
Managed to get a fair bit done this weekend, which has supprised me as I spent ost of the day at work yesterday. Most of the stuff in the bay is now all in and tightened up and staying that way!!! (the amount of times the manifold etc has been out is unreal) New rad is in, and this one made it in in one piece! Turbo elbow and down pipe are all welded back together and are in, all the is left to be done id fabricate a clam to support the down pipe.
Edited by shane on 13th Apr, 2008. |
