| Home > Help Needed / General Tech Chat > Will it fail the MOT ? | |||||||
![]() 862 Posts Member #: 1660 Formally Mini_Uk London |
2nd Apr, 2008 at 11:18:30pm
Maybe silly question, how about the washer bottle, does this have to be fitted. as ive left mine off. but can fit it no problem ? Shit Happen's |
2nd Apr, 2008 at 11:26:58pm
put it on, just incase |
2nd Apr, 2008 at 11:28:57pm
On 2nd Apr, 2008 Nic said:
put it on, just incase Think i wiil.. as im told this place is very stricked.. Shit Happen's |
2nd Apr, 2008 at 11:30:35pm
why didnt you go somewhere more mini friendly? |
2nd Apr, 2008 at 11:42:05pm
well i normaly go to a mate in london where i live. but as im in kent and thats where i done me car, i need MOT to get me tax disc :) that y im doing it down here. Shit Happen's |
3rd Apr, 2008 at 05:43:05pm
On 2nd Apr, 2008 Mini_Uk said:
Maybe silly question, how about the washer bottle, does this have to be fitted. as ive left mine off. but can fit it no problem ? Working wipers and screen wash are a legal requirement, and must be working for MOT..... Although they may not always check. 9.85 @ 145mph
4th Apr, 2008 at 10:21:16am
Agreed, you will be failed for having an empty washer bottle, nevermind not having one at all! |
4th Apr, 2008 at 10:22:53am
I have to fit my washer bottle in the passenger footwell every year..Lol https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
4th Apr, 2008 at 06:38:22pm
It failed MOT :(
Shit Happen's |
4th Apr, 2008 at 06:45:04pm
drops do move on idle unless the clutch is pressed down. On 28th Aug, 2011 Kean said:
4th Apr, 2008 at 07:04:30pm
On 4th Apr, 2008 mini13 said:
drops do move on idle unless the clutch is pressed down. Thought so.. what a dick head... grrrrrr, makes me mad when u get wankers telling u stuff when they dont know what there talking about... Shit do happen lol Shit Happen's |
4th Apr, 2008 at 08:39:59pm
How could i check it's not the release bearing.. ???????? lol Shit Happen's |
4th Apr, 2008 at 09:00:39pm
take the 2 bolts out that hold the clutch slave cylinder to the flywheel housing and move the slave so the clutch arm can be operated by hand.
![]() 152 Posts Member #: 1662 Advanced Member manchester |
6th Apr, 2008 at 01:21:50am
front fog lights and reverse light aren't on the list, rear fog light has to work, as does hazards, you may get away with hazards, but unlikely, i work part time at a garage Edited by aml on 6th Apr, 2008. |
6th Apr, 2008 at 08:41:55am
i would of thought 1980 was before the fog light requirement to be honest. if it hasnt ever had one fitted then they cant make you have on fitted. |
6th Apr, 2008 at 09:32:10am
I thought rear fog light was only testable after 1983, but I just Gooooogled and in fact the cut off date is April 1980, hence them asking when in 1980 your car was first used.
6th Apr, 2008 at 04:55:03pm
On 6th Apr, 2008 Tom Fenton said:
I thought rear fog light was only testable after 1983, but I just Gooooogled and in fact the cut off date is April 1980, hence them asking when in 1980 your car was first used. Yep your right there tom. Mine is september 1980 :( would that be front also.. as the test just failed on no rear fog light hmmm.. odd how this has never been spotted. i didn't even know. he said he pass it on monday. but problem is, as it failed on efficiency braking, and they said just addjust the rear shoes. which i have now done. but it just seems back to the way it was, the brakes feel fine to me. im just wandering if the braking efficiency is maniley for modern day cars on there machine, and not so much older cars like mine. im just using standard braking. stops great. just worried the computer will fail it again. cant fog out another £50 :( Shit Happen's |
6th Apr, 2008 at 05:36:14pm
Not front fog lights no, these are not compulsary on any age of car.
6th Apr, 2008 at 05:45:30pm
I have "helped" rear shoes to bed in by lightly using the handbrake a few times while going along,
6th Apr, 2008 at 09:32:55pm
erm
Edited by Bat on 6th Apr, 2008. VEMs Authorised Installer / Re-seller. K head kits now available!
6th Apr, 2008 at 10:24:20pm
On 6th Apr, 2008 Bat said:
erm just the advise i was about to give
7th Apr, 2008 at 05:10:32pm
Well the bugger passed today :)
Shit Happen's |
7th Apr, 2008 at 05:53:05pm
well done mate
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
7th Apr, 2008 at 06:10:59pm
On 6th Apr, 2008 Tom Fenton said: .
However when working right they should easily pass the MOT efficiency check. Adjust the shoes right up until the wheel starts to bind, and then very gradually back them off till the wheel is "just" free with a bit of dragging on the shoes. Obviously not too tight, but they don't want to be completely free either. I have once spend a whole weekend and used 3 liter of brake fluid trying to get a firm pedal on my drum braked mini before i put Cooper S disks on using the method you describe (as per haynes). i did it like that.. turns out that the Master is fairly small compared to the volume of four (six) drum brake cylinders. A mate of my dad dropped by .looked at it for 3 minutes..then sorted it. (voila from no pedal pressure to a good firm pedal..and slightly bruised ego) this is how i do it now.. 1- take the wheel off. 2- put the wheelnuts back on the drum finger tight. 3- adjust untill frigging tight. 4- take a hammer (with a block of wood or a big rubber one used to street work) whack it semi-hard all around..(carefull with minifins) centering the shoes within the drum 5- 90% chance it will be fully loose now. 6- go to 3 adjust untill it only slightly drags. That sir, is not rust, it is the progressive mass reduction system
7th Apr, 2008 at 08:03:31pm
Good show old chap, what! what!
