Home > Help Needed / General Tech Chat > im getting so annoyed now. pistons and rod help again !
On 1st Mar, 2011 Joe C said:
Waaaay overkill,
std pistons and rods will be more than enough,
I'd stay away from the JE's, they are a good piston but with the short height I think they are going to be a pain to get the block decked enough.
cast omegas?
http://www.avrclassics.co.uk/_-Omega_Cast_...duct/?pid=47824
JEs can be anything you want though.
I reckon there are better ways to spend £1k especially on a turbo lump.
On 2nd Mar, 2011 Paul R said:
What makes you say this?? I have been thinking of putting there crank amd rod set on my to buy list, overkill or something else??
On 1st Mar, 2011 fastcarl said:
they do?
On 1st Mar, 2011 supermotolee said:
specialist components make nice cranks and rods for good money
Gaball
Member #: 7169
Gobshite that posts wank videos.
Somerset, UK
If your concerned about the rods get them balanced and polished and they are fine. Have to love over engineering :)
Gaball said:
Motorsport Engineering Student
Project Car 1293 Turbo Mini (on a student budget)
On 7th Oct, 2010 apbellamy said:
Carbon but plug?
i htink its safe to asume that the only rods made here in the uk will be Arrow,
I may be wrong but these rods at £300 a set are cheap for a reason,
Arrow rods are getting on for £900 a set for a very good reason,
i wopuld like to think that Swiftune had there rods made here in the uk, for the price they have put on them,
as has ben siad previously90- 95% of machined components sold in mags for the aftermarket car sector are made in the far east,
if any "retailer" marketer claims that they are manufacturing i would suggest you ask to see there facilities,
don't you find it a little strange when some mini suppliers have no idea when they are getting there next batch of whatever in,
carl
I'd still like to know waht all this double air re met is all about. I'm leaning towards it being a term that baffles the buyer, in that because they don't know what it is, it must be a special process and the reason why you pay over the odds. Now im not saying that these rods do not have some sort of special heat treatment, but the process itself is NOT called double air re melt. All the well known rod manufacturers use this term. Infact Google turns up nop other results other than ones about said rods.
Edited by Sprocket on 2nd Mar, 2011.
http://www.arrowprecision.co.uk/production_notes.html
Vacuum de-gassed nickel chrome alloy steel.
Double air remelt is not a term I'm especially familiar with, and that is coming from someone who works in the steel industry, and more specifically, at a plant that makes engineering steels, so alloy forging steels that you would reasonably expect rods to be made from.
The whole remelting in air concept is also a strange one- in all the treatment of steel, you are constantly striving to keep air or specifically oxygen OUT, as the presence of oxygen when steel is molten causes a reaction and creates iron oxides, rust to you and me, impurities in the grain structure to a manufacturer.
We process some of our steels, mainly for the aero industry, buy either vacuum arc remelting, or electroslag remelting. This already follows a vacuum degassing procedure when the steel was molten in the first place to remove gas bubbles and impurities, the entire steel ladle of 160T of molten plus 90T of ladle and refractory is placed in a tank, the atmosphere is then removed down to less than 1 mbar for most treatments. The remelting procedures mentioned above are carried out once the molten steel has been cast into ingots and is solid. It is then melted again in a slow process, the Electroslag uses slag covering to flux and remove impurities, the Vacuum Arc process remelts the ingot in a vaccum, hence removing impurities and gasses to give very high cleanliness steel.
But air remelt? Not one I'm familiar with.
To quote from Arrow on the link John posted
Vacuum de-gassed nickel chrome alloy steel (Double-air-re-melt)
It looks like it is a term coined by Arrow, and everyone one else is either using it to keep up with the big boys
I would get someone who knows there onions on the charged A series to build your engine, your mates may be decent blokes but there giving you open wallet surgery that is not needed.
Speak to turbophil or benross on here i think there localish to you
On 1st Mar, 2011 andyuk1275 said:
ive looked in to the cast omegas. these 2 blokes both build supras and skylines so there forged all the way, has anyone ever had bother with cast pistons because im really getting annoyed with everything now :/
I understand why hbeam rods are used because of strenght and there weight (when manufactured properly) i geussed there better for higher reving engines as i belive most use a+ worked rods such as you do carl. But as for the crank though, wouldnt a forged large counter ballance crank be more reliable than a a+ crank that has been worked?? Less vibration less chance of falier from what i can gather or am i wrong??
SC crank doesn't look to have large counter balances to me.
last time i looked the sc billit crank looked like a standard cast crank
Problem i see is cost when it goes wrong Paul, if i had bought a steel crank when my thrusts went i would be scrapping a £1.5k crank and rods rather than a £300 crank and rods.
If standard but reworked is perfect for a big power charged A series then why buy a crank thats really for a high revving A series.
Nothing wrong with having the best if you have plenty of cash but if you dont have plenty of cash............
I vote wrong. Name me one person who has had a crank fail?
or a con rod break (when not caused by the big end faliure)?
Well thank you guys for clearing that one, tbh i havent seen of any faliures that hasent been caused by oil starvation of a bad build up, i wasnt on about the sc crank but med and swifteys new faux 5 bearing crank. Tbh the look of fully worked rods looks proper cool all nice and shiney *smiley*)
shiny doesn't matter you never see em.
Shiney means smoother serfices and less oil drag *wink*
Rick.SPI
Member #: 8027
Smoother means no stress points, so less likely to break, but as said shiner means nothing unless you have a see through engine *wink*
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=326426
carl
Farndon ? Capricorn ? maybe
Either way...regarding cheap rods.
They are sold all over the world for many applications. Japanese, American etc I use cheap rods in my engine. First set I bought cost US $450 for 8.
And I spin them on a 4.0" stroke crank, with a 4.0" bore piston to 7000rpm. No problem.
Although the price has now risen to around $600 for 8.
Ive fitted dozens of "cheap" rods to Subarus. Never once seen a failure despite years of abuse.. In fact the only aftermarket rod Ive had fail in a Subaru engine, was an expensive Pauter rod. The cheap Subaru rods tend to retail around £3-400
So for anyone to ask £740 for a set of 4 rods. Does seem a tad over the odds.
But all of the above is irrelevant to this case.
I'd be asking the seller to show how many std A+ rods that have broken to justify aftermarket rods at such a price.
I'd suspect he doesnt have too many
I'd seen that one. But after a search I've found evidence of 3 broken cranks on thist site. Not bad for 7979 members and well over 5 years.
I have seen a broken crank some years ago, same place as the one above. The engine still ran funilly enough. It was in a standard metro engine, so its got fuck all to do with performance, and more to do with fatigue. Perhaps as a result of an un balanced flywheel.
I agree though that the number of broken cranks could well be counted on perhaps one hand considering the actual number of cranks in high performance engines.
I'll never forget thta celebrity race thing where Melissa Joan Hart (phwar!! *happy*) managed to snap the crank on a Mini Seven by missing a gear entering a corner, and buzzed the little thing to well over 10K
Come on Col, standard or modified A series engines will only ever have one crank installed *hehe!*
