| Home > Help Needed / General Tech Chat > HuddersField Spares, Coil Overs | |||||||
8 Posts Member #: 603 Junior Member |
7th Jul, 2005 at 09:14:33pm
just noticed in this pic the use of upsidedown shocks
7th Jul, 2005 at 10:29:16pm
Thats mike greens miglia, that is kept in the same workshop as my mini, you may notice the same shocks on my car.
7th Jul, 2005 at 11:40:41pm
Whats with the new subs and the bass box :$
8th Jul, 2005 at 01:09:58am
On 07/07/2005 22:29:16 Jimster said:
why do you say they are upside down? We just removed the dust seals from them thats all. oops.......sorry yeah i can see that now
![]() 214 Posts Member #: 1574 Senior Member Malta |
17th Mar, 2007 at 04:38:30pm
Can someone be clear on why everyone thinks coil overs are no good? I have modded my bodywork to fit coil overs with 12" wheels, although havent fitted them yet. If they are this much hassle I may settle for a decent hiLo set up with some Koni adjustables.
17th Mar, 2007 at 04:53:47pm
Not everybody ..... I use them and would never go back!!!!
17th Mar, 2007 at 05:01:03pm
Its sounds like its down to personal taste and a bit of effort then. Maybe I'll try the type you mention. I reinforced my suspension mount anyway. Do you know if the Protech version is of similar size to AVO's as these are what I modelled my body nod on?
17th Mar, 2007 at 05:02:03pm
It's the "beams" that have been the problem, most aren't all that stiff and not up to the job of keeping it all pointed in the right direction.
17th Mar, 2007 at 05:03:45pm
I think the protech rears are set up for 1.9" dia springs ..... what size spring was used on the AVO's you measured? Every day is a school day ...........
17th Mar, 2007 at 07:11:08pm
784 Posts Member #: 912 Post Whore North Yorkshire |
17th Mar, 2007 at 07:53:57pm
Yeah,
I drill holes in everything..! |
19th Mar, 2007 at 07:58:52pm
The Protech spring seems a small diameter. The Avo spring is 66mm measured from outside to outside of the spring. When you mention 'beam' what are you referring to? Like many its the rear that is the most concerning as the front has to have a 'conversion' to support the spring anyway. I can post pix if it helps.
19th Mar, 2007 at 08:08:43pm
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
19th Mar, 2007 at 11:25:21pm
I think its personal preference, each driver may have different expectations of how they want their car to feel and handle, not to mention driving style, and with so many combinations of parts , manifactures etc, it seems to be a little trial and error.
24th Mar, 2007 at 10:48:58am
Guys,
24th Mar, 2007 at 01:45:54pm
It is that simple!!!!!
24th Mar, 2007 at 04:41:18pm
Thanks Roger. Thats the job for next week then. I'll post some progress pix as I go so anyone else who has this query can follow what I've done.
![]() 52 Posts Member #: 75 Advanced Member |
19th Mar, 2009 at 09:32:37am
I am currently rebuilding my rear suspension, The car will be fairly light, with no back seat , carbon bootfloor, rear beam, carbon boot lid and I have some kad radius arms. I read that RogerM then recomends the lowered spax coilovers. Have there been any new research on this? or are they still the recomended item? I've heard that scruffy have a lot of experience, do you have any tips?
![]() 338 Posts Member #: 1911 Senior Member Swindon |
19th Mar, 2009 at 04:42:01pm
I had Spax coilovers from minispares on my car and used it on the road. I was also after lowering it and to be honest it wasn't low enough for me and was far to hard even on it's softest setting.
19th Mar, 2009 at 04:44:02pm
Then he looks at the date of the posts ... |
19th Mar, 2009 at 10:01:01pm
I found a old post that adressed some of my problems, while researching.
19th Mar, 2009 at 10:01:04pm
![]() 367 Posts Member #: 1643 Senior Member West London |
19th Mar, 2009 at 10:14:53pm
Can you fit a rear ARB with coilovers on the rear?!
Lightweight racer coming soon. |
20th Mar, 2009 at 07:05:25am
yes |
20th Mar, 2009 at 08:01:00am
It is a lot of work - it does not make the handling any better and in many cases it can be worse especially with the super bendy speedex type beam that this company has copied. You also need expensive shocks such as trakspax to make it worthwhile. It is only worthwhile for the weight saving.
On 5th Sep, 2011 Vegard said:
