| Home > General Chat > Group buy?? | |||||||
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
13th Jan, 2014 at 10:29:16am
I've found the secret to the roll pin is to use the biggest hammer you can find.
Metric is for people who can't do fractions. |
13th Jan, 2014 at 10:40:41am
THIRTY SIX POUNDS!!! THIRTY SIX FECKING POUNDS!!!
13th Jan, 2014 at 11:08:35am
On 13th Jan, 2014 Tom Fenton said:
THIRTY SIX POUNDS!!! THIRTY SIX FECKING POUNDS!!! Learn to swing a hammer you bunch of poofs! Hahaha! Either that or learn how to screw your car together properly so the engine isn't in and out every 2 mins! If something is worth doing, it's worth doing half of. |
13th Jan, 2014 at 11:10:42am
Not much that cant be solved with a 2 1/2 lb lumphammer, but having the right tool is half the job. On 26th Jan, 2012 Tom Fenton said:
13th Jan, 2014 at 01:32:21pm
No more fighting with those roll pins can only be a good thing.
Edited by Mr Joshua on 13th Jan, 2014. Own the day
13th Jan, 2014 at 01:58:01pm
Put it in reverse. Proper stepped punch for the task in hand. Knock it out. Done. I don't and never have understood why folk find this so difficult.
13th Jan, 2014 at 02:05:03pm
I've found that the trick is to get the car high enough to be able to swing said percussive correction tool. If something is worth doing, it's worth doing half of. |
13th Jan, 2014 at 02:08:22pm
It's much easier with the car in the air I agree, but if you crawl underneath and keep swinging it'll come out eventually. Wd40 sometimes helps. On 26th Jan, 2012 Tom Fenton said:
![]() 23 Posts Member #: 10709 Member Gap |
13th Jan, 2014 at 02:50:34pm
Ah ah, you just have to lift the car by the front of the subframe as high as you can and put your head under the gearbox!!! (be carefull to well secure the car ) and punch the pin in after put the gear stick in reverse position....and that's all, you save 36 pounds !!!!! |
13th Jan, 2014 at 04:44:23pm
I agree with Tom. Stick it in reverse and knock out the pin closest to the gearbox. There is no need to do this with the car jacked high either On 26th Oct, 2004 TurboDave16v said:
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
13th Jan, 2014 at 04:56:56pm
The hardest part is jacking the mini up. What the mind can conceive the mini can achieve
13th Jan, 2014 at 05:04:49pm
No need to Jack it up anymore lol that's so yesterday. Own the day
13th Jan, 2014 at 06:37:38pm
and a quick way for someone to make it an easy trip home on a flat bed On 26th Oct, 2004 TurboDave16v said:
13th Jan, 2014 at 06:59:58pm
I find the stands get in the way when I try and swing the BFH. On 11th Feb, 2015 robert said:
13th Jan, 2014 at 07:06:15pm
I just have mechanical sympathy. Twatting the fuck out of a cantilevered rod hanging out of a support in an alloy housing, and resorting to a bigger hammer when the bad boy doesn't shift, is something that just doesn't feel right to me.
809 Posts Member #: 224 Post Whore Katy TEXAS |
14th Jan, 2014 at 02:04:19am
I totally agree Dave
On 13th Jan, 2014 TurboDave16V said:
I just have mechanical sympathy. Twatting the fuck out of a cantilevered rod hanging out of a support in an alloy housing, and resorting to a bigger hammer when the bad boy doesn't shift, is something that just doesn't feel right to me. I had one many years ago that was seemingly welded in place; it would mushroom out the pin punch and just not shift the roll pin. Ultimately I had to pop the other roll pin, and ended up managing to get the other one out on the bench using heat and mole grips to squeeze it out. I do like the speed with which this minispares one might be able to be removed. Still isn't going to make me buy one though BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
1170 Posts Member #: 8636 Post Whore Surrey |
14th Jan, 2014 at 01:52:12pm
i am,
Edited by WRLondon on 14th Jan, 2014. Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
14th Jan, 2014 at 02:06:45pm
have to say, I remember back in the day cursing trying to get out a variety of these pins before I made a short punch pin with a centre point to aid location. I hold it with some long nose mole grips so I don't have to worry about twatting my hand/fingers with the appropriately sized hammer. Never had an issue since |
14th Jan, 2014 at 03:34:18pm
On 14th Jan, 2014 Rob Gavin said:
have to say, I remember back in the day cursing trying to get out a variety of these pins before I made a short punch pin with a centre point to aid location. I hold it with some long nose mole grips so I don't have to worry about twatting my hand/fingers with the appropriately sized hammer. Never had an issue since What the mind can conceive the mini can achieve
14th Jan, 2014 at 03:46:52pm
This chap has the right idea!
14th Jan, 2014 at 03:47:21pm
I like to think of it as a technical adjuster |
14th Jan, 2014 at 06:53:42pm
I like to think of it as a technical adjuster Edinburgh socket set..... On 26th Oct, 2004 TurboDave16v said:
