| Home > Help Needed / General Tech Chat > starter motor no go!! | |||||||
1300 Posts Member #: 829 Post Whore essex |
6th Apr, 2006 at 01:50:19pm
the flywheel on the engine is it yours or did you buy it ?? to put on the new engine also take the starter to the spares shop to check you have the right starter for the engine 1293 Turbo mini
236 Posts Member #: 243 Senior Member Portsmouth |
6th Apr, 2006 at 05:25:04pm
flywheel was already on the engine just put it back on. Looks the same fly wheel as the one on other turbo engine i took out of my mini, Which is verto.
WooHoo Passed it's MOT!!!! One of the cars in The Portsmouth Mini Turbo Massive!!
133 Posts Member #: 703 Advanced Member Plymouth, On the floating skip known as HMS Albion |
7th Apr, 2006 at 09:51:22pm
Have you tried a different type of starter i.e inertia and not pre-engaged?
Whats going to break next!?
7th Apr, 2006 at 10:31:57pm
pre verto ring gear can be fitted to a verto flywheel.
7th Apr, 2006 at 10:58:30pm
8th Apr, 2006 at 11:20:08am
its one cylinder shaped lump with the starter solenoid fixed to the wing.
Edited by m4dn35s on 8th Apr, 2006. WooHoo Passed it's MOT!!!! One of the cars in The Portsmouth Mini Turbo Massive!!
![]() 2102 Posts Member #: 432 Post Whore Swindon |
8th Apr, 2006 at 11:38:26am
IIR then if there is 1 termainal on the starter then you need a solinoid, if there is 2 then you dont.....
8th Apr, 2006 at 12:47:54pm
actually just checked.
8th Apr, 2006 at 01:20:46pm
yer its got one terminal on it, just looked at the ring gear well felt it as its in car and couldnt see it all that well but def feels sharper on the edges than the one on my other enginewhich is def verto,
9th Apr, 2006 at 05:38:00pm
On 08/04/2006 13:20:46 m4dn35s said:
think il try the non-verto starter and see if that works cos both starter motors iv tried so far are verto! Eh?! The inertia type starter, which uses a seperate solenoid mounted on the inner wing mates with the EARLY type NON-VERTO flywheel. From what you have been saying, this is the type of starter you have been using. The pre-engaged type starter, with the solenoid built on the side, mates with the VERTO type flywheel.
18th Apr, 2006 at 11:40:45am
Hi all, Thanks for all the advice.
18th Apr, 2006 at 05:58:08pm
