| Home > Help Needed / General Tech Chat > It IS an R5 Turbo, what now? | |||||||
6th May, 2006 at 09:45:49am
axel,
Edited by robert on 6th May, 2006. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
6th May, 2006 at 12:14:38pm
Pete I am very interested in the methods of getting TIP<MAP, I'd like some more info on this, PM if you like....
6th May, 2006 at 12:48:07pm
peter ,if yuor tip is over the mip ,all the way thruogh the range ,id suggest yuor using a dynamic pickup for the tip and a static for the mip. usually on a reasonable response versus top end bhp design ,the crossover point is about pk torque if its all matched, if there are no points in your engine wherethe mip is higher than tip theres something wrong somewhere if using static pressure pickups all thruoghout ,regards robert . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
6th May, 2006 at 01:11:56pm
On 06/05/2006 09:31:33 Axel said:
The smaller turbine of the T2 will create more exhaust pressure than the larger T3. hmmm yes it does - which then effects the induction stroke. As I've said before, a turbo links your Inlet and Exh stokes together much more that in an NA :) Alex AlexF |
7th May, 2006 at 09:06:11am
Ivanhoew,
7th May, 2006 at 11:28:32am
i know i am a bit thick like and all this has gone way over my head
7th May, 2006 at 11:44:37am
You've got it spot on Wolfie.
7th May, 2006 at 12:43:49pm
peter ,check your pm Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
17th Nov, 2006 at 11:52:59pm
oh, I remember this post....
Edited by turbodave16v on 17th Nov, 2006. On 17th Nov, 2014 Tom Fenton said:
18th Nov, 2006 at 08:32:58am
Oh dave !
18th Nov, 2006 at 08:36:39am
wil
18th Nov, 2006 at 10:30:18am
Thanks for the map Dave.
18th Nov, 2006 at 10:52:08am
Just printed the map and, guess what, my calcs were correct.
