| Home > MS Trials & Testing > Bench testing the siamese code *** Updated code | |||||||
2nd Mar, 2007 at 02:45:37am
For those interested in bench testing, I've designed a small board to help scope the signals and ease the input of a 36-1 signal into the MS. This will also be useful when setting up a system in a car. You can have a look at my post on the megasquirt forum: http://www.msefi.com/viewtopic.php?p=161149#161149.
![]() 10 Posts Member #: 1539 Member Denver, Colorado |
2nd Mar, 2007 at 03:13:50am
Dave, are you really in South Park, CO? if so im only 85 miles away in Denver, mabye I can help out with the testing "sorry, Jedi mind tricks don't work on retards" Mediocre Films 2008 |
10th Apr, 2007 at 07:36:40pm
BOING!!!!
11th Apr, 2007 at 12:01:18am
Dave, pm sent.
15th Apr, 2007 at 02:48:38pm
nice to see your alive chap, wondered where you had gotten too :) turbo 16v k-series 11.9@118.9 :)
15th Apr, 2007 at 03:43:58pm
Hi Peter,
16th Apr, 2007 at 06:30:28pm
Peter .. so which is it ... rwd or a different gearbox? Every day is a school day ...........
16th Apr, 2007 at 06:56:13pm
Has the Magazine been shelved then Peter what with you working away?
16th Apr, 2007 at 07:35:23pm
I had a feeling ... LOL
17th Apr, 2007 at 05:34:26pm
was just looking at a meastro in a breakers and my thought way "thats wide".
17th Apr, 2007 at 05:57:53pm
On 17th of Apr, 2007 at 05:34pm RogerM said:
if I was going to all that trouble I'd be thinking of a different engine to be honest. Can't agree with that enough. sure, it's an a-series, but I'd much sooner see a decent motor liek a 4AGE in there instead. On 17th Nov, 2014 Tom Fenton said:
17th Apr, 2007 at 06:20:14pm
Look forward to seeing it when done but if I was going to all that trouble I'd be thinking of a different engine to be honest. It seems a lot of work to me too, and changing the gearbox will move the car into sports libra for hillclimb/sprinting. I guess it is a stronger 5 speed box for the road. Nothing is to much for Peter though, will we be seeing anything at Avon park this year? http://www.twin-turbo.co.uk
17th Apr, 2007 at 06:32:25pm
4age .... oh yes ..... Every day is a school day ...........
17th Apr, 2007 at 08:29:41pm
cant understand people doing things differently myself , Edited by robert on 17th Apr, 2007. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
17 Posts Member #: 1555 Member |
3rd Sep, 2007 at 07:01:37pm
hi there just wondering how the code is coming along.
5th Sep, 2007 at 01:23:59am
There is a version of the code that seems to work on the bench but there hasn't been any other validation done by anyone but me. It is also based on an early version of the MS2/extra code. I am working on a newer version based on the latest version of the MS2/extra code but it's not yet ready.
5th Sep, 2007 at 07:23:32am
I know I've been slack on this Jean .....
5th Sep, 2007 at 08:26:18am
ok jean thanks for the reply i had a feeling the 36-4 would cause problems so will repace the missing teeth and leave just the one at 40deg btdc was hoping for just over the 130 bhp mark so i guess ill have to source some bigger injectors would these injectors i have still not be big enough even running at the higher end of there scope at 420cc what size would you recommend as a minimum many thanks |
5th Sep, 2007 at 04:17:41pm
I also have had other familly stuff taking priority over this... Apologies. :( On 17th Nov, 2014 Tom Fenton said:
5th Sep, 2007 at 05:19:50pm
On a more positive note, once I've got the car and the wifes 35 MOTd I shall be getting back to this.
5th Sep, 2007 at 09:26:58pm
On 5th of Sep, 2007 at 07:23am RogerM said:
I know I've been slack on this Jean ..... I now have everything I need to test properly except time (and an MS2 not in a car ..... can just be pulley out though) I haven't fogotten that I said I would do this further testing. I will mail you later and we hopefully can move this forward. I'm tied up for the next couple of weeks (spraying, watch the MGs at Coombe and entertains some ladies) but when I'm done I'll pop up for a weekend to give you a hand to get the test bed up and running. Isambard Kingdom Brunel said:
6th Sep, 2007 at 12:00:35am
Not being funny but how many times do I need to post up the tooth format of the MPI reluctor before anyone actualy takes any notice.
On 30th of May, 2006 at 09:56pm Mini Sprocket said:
To quote from the Rover workshop manual "The flywheel incorporates a reluctor ring which consists of 32 poles spaced at 10° intervals, with 4 missing poles at 30°,60°, 210° and 250°. The missing poles inform the ECM when to operate the groups of injectors. The camshaft position sensor has two functions. The first is to enable the ECM to run a sequential fuelling mode. The second is to measure the actual cam period, this measurement is achieved using teeth on the camshaft to indicate when the valve opens and closes." http://www.turbominis.co.uk/forums/index.php?p=vt&tid=171104 On 13th of Aug, 2007 at 10:26pm Mini Sprocket said:
MPi flywheel data Missing teeth at 30, 60, 210 and 250. There is 2 teeth between 30 and 60, 14 teeth between 60 and 210, 3 teeth between 210 and 250, 13 teeth between 250 and 30. 0 being TDC on #1/4 cylinder (TDC1) 180 being TDC on #2/3 cylinder (TDC2) It is documented in the rover workshop manual. And been available for quite some time :- And please dont take this post as negative. I would in the depths of my heart like to see this working :) Edited by Sprocket on 6th Sep, 2007. On 26th Oct, 2004 TurboDave16v said:
6th Sep, 2007 at 12:56:06am
Thank you Mini Sprocket. I'm sorry I forgot about that and I was a bit lazy in searching for it.
6th Sep, 2007 at 12:59:53am
On 5th of Sep, 2007 at 08:26am minimiglia0 said:
ok jean thanks for the reply i had a feeling the 36-4 would cause problems so will repace the missing teeth and leave just the one at 40deg btdc was hoping for just over the 130 bhp mark so i guess ill have to source some bigger injectors would these injectors i have still not be big enough even running at the higher end of there scope at 420cc what size would you recommend as a minimum many thanks You're probably going to be ok with that power level but you'll have to watch the duty cycle to make sure that it doesn't go too high. Otherwise you'll be injecting outside the injection window and you'll have one lean pair of cylinders and one rich pair. Jean |
6th Sep, 2007 at 01:27:13am
I now have the MPi cam so will slot it into a block and time it up then see where the signal occurs.
