Home > Show Us Yours! > Rear Engined K-Series Mini
progressing well, can i ask what its like working on chequer plate flooring?
jakelloyd99
Member #: 5310
Oxford/Hertford
cheers mate, its no too bad its worn a bit since it was new so its less sharp( the edges of the bumps are a bit softer). its grippy when its dry, slippy when its wet like painted concrete. and the main reason is that the garage has underfloor heating. the metal conducts very well compared to a concrete slab. it only gets turned on when is is cold. the inside skin of the garage wall is 150fibrelite blocks, thicker than the standard 100 mm so you get a greater amount of thermal lag. so when you open the door and all the hot air escapes the heat is retained in the walls and reduces the fluctuation of tempprature. lol got a bit carried away their!
jakelloyd99
Member #: 5310
Oxford/Hertford
mini_steve
Member #: 1888
Doddington , march
Nice!
never underestimate a mini!
jakelloyd99
Member #: 5310
Oxford/Hertford
got some more done this weekend. decised to take the bumper off the back.
thease are the front bottom subframe mounts
steering coloum mount
rear hoop bracket boxed in ready to take the second door bar. need to get the door bars and harness bars sorted soon. also a seat frame to take the side mounts.
jakelloyd99
Member #: 5310
Oxford/Hertford
jakelloyd99
Member #: 5310
Oxford/Hertford
I love projects that move this fast. You clearly don't have childeren, and maybe not a wife/girlfrien either.
If you do I'm jealous
Nice Skills
Pottsy
Member #: 843
Stoke-on-Trent. Duck.
... or don't have a job?! I suspect a possible Lottery winner.
Natlloyd
Member #: 7237
hertfordshire
Ive made made my own account now.
Nat
jakelloyd99
Member #: 5310
Oxford/Hertford
You have been a busy boy! ha ha he's got a job and a girlfriend!!
jakelloyd99
Member #: 5310
Oxford/Hertford
found some old pics of when my bros mini was first on the road (2003)
Natlloyd
Member #: 7237
hertfordshire
Natlloyd
Member #: 7237
hertfordshire
i need to get some primer on the car as soon as possible realy. its going to be the same coloul again eventually. also need to get a flif front sorted any suggestions? thanks
Edited by Natlloyd on 5th Oct, 2009.
Natlloyd
Member #: 7237
hertfordshire
i think im going to go to abs motorsport for the front end. £115 for a fibreglass front and a bonnet but they charge £30 delevery.
im going to get the door bars and harness bars sorted this week. im tacking the shell to fabricage so they can scolop the ends and i might have more of a chance of getting the welds looking respectable.
Natlloyd
Member #: 7237
hertfordshire
Natlloyd
Member #: 7237
hertfordshire
Natlloyd
Member #: 7237
hertfordshire
im not too sure how to mount the brackets that the clips will fit to for the front end does any one have any advice? thanks.
Natlloyd
Member #: 7237
hertfordshire
Brocky
Member #: 224
Katy TEXAS
Nice,
Looks like its gonna be a monster,
Keep up the good work !!
Gunny
Member #: 7429
Leicester
awesome!
'89 Austin Metro GTa :)
Comming along nicely.
I'm not a big fan of the Dzus fasteners. as you have a removeable bonnet you may as well have the front end more permanently fixed. If you wanted it neat you could mould some brackets on the back of the panel, otherwise some nice stainless bolts may do the job.
I made up some angle plate out of alloy and used the door hinge bolts to hold it behind the a panel
you can see it here (just):
Natlloyd
Member #: 7237
hertfordshire
ahh rite im gna have a think before i start chopping holes in it then!
