Home > Show Us Yours! > project for life..
turbo22
Member #: 3684
wisborough green west sussex
pics
turbo22
Member #: 3684
Havnt had a chance to do much due to work but have managed to get front end almost there.
Bonnet fitted just some fine tuning to do, grill fitted, towing eyes in, zeus fastner fixings all sorted and working well.
Dash and dials in and all working showing a good oil presure and water temp, not sure on boost guage though will it only show readings under load?.
Managed to source a nearly new safty devices rear cage with diag for only £50 so have fitted and removed and at present it is being re-sprayed.
A few pics ill get more up when i get the cage in this week.
turbo22
Member #: 3684
sim_ou_nao
Member #: 114
Porto/Portugal
very nice *surprised*
Pedro Silva
turbo22
Member #: 3684
cage painted and in.
turbo22
Member #: 3684
Small update.
Got a little more done dash in and all wiring finished also put some vent holes in the bonnet for the intercooler.
turbo22
Member #: 3684
pics
rosco454
Member #: 5222
Northumberland
I seem to have missed this one somehow.It looks great especially the wheels,as a wheel nerd I would go out on a limb and say they are schmidt th lines not compomotive turbos but they look great whichever way and really suit the car.
Cheers Ross.
Th lines have a smoother rim than thoes do
Oli
Member #: 1910
Wilts
yeah i wouldnt say theyre th's either.
You into euro look paul?
rosco454
Member #: 5222
Northumberland
Your both quite right,I had meant to write centre sections.The th have a large smooth are on the dish where the valve mounts.
Cheers Ross.
turbo22
Member #: 3684
Just ahd a look at the TH lines and they indeed do look similar so maybe they are a mix of both?. Not bad for a fleebay find though! just need to get them re-furbed now.
turbo22
Member #: 3684
Small update, chopped the doors about to loose some weight, then machined up so bits and came up with this design, all in one opener and handle. Hand grip is fixxed with a grub screw so it can be moved up and down the rod as to suit to person.
turbo22
Member #: 3684
bootlid also finished, welded in some plate strips to drop into small slits cut out of boot surround then fasten with pins in corners.
I like the door opener. Still plenty of space for swaged holes in the sides of the door frames though.
turbo22
Member #: 3684
might look into that now, didnt realize this was dooable.
It's mainly flat steel, so swaged holes will make it stronger *smiley*. I plan to do that to my doors
turbo22
Member #: 3684
nice one just looked at some on here, looks the part. A job for next week i think.
wez
Member #: 9271
Stoke on Trent
Nice build youve got here, love the wheels and the colour of the block.
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
turbo22
Member #: 3684
cheers, just need to get it finished! desperate to drive it.
Advantage
Member #: 1450
Near Paris - France
I bet !
Rusty by nature
turbo22
Member #: 3684
too date, ready for mot tomorrow. Fingers crossed!.
turbo22
Member #: 3684
turbo22
Member #: 3684
few more.
danb41
Member #: 9285
Oxfordshire
very cool, don't see many minis with those wheels!
