| Home > Help Needed / General Tech Chat > T2 And T3 | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
19th Jul, 2006 at 12:35:47am
About to do a rebuild and wondering which is the best turbo to put in going have them both re done but which would be the best i have one off the metro or off R5 and i was wondering cos i would of thought that the T2 turbo would be the best cos its water cooled but it blow up on the R5 and lots of people i know saying that they weren't that good. Do they hold more power though than the metro turbo?? And theres a different set up you can have with t2 does that give you more gane? and on metro turbo i take it there will be more to bore out so maybe it doesn't?
19th Jul, 2006 at 09:47:31am
look at the tech section as i did an artical on the benifits of both. the T2 is good up to say 10psi but cannot cope with 15psi unless its been modified |
19th Jul, 2006 at 12:50:27pm
when you say carnt cope with over 10psi, do you mean it will break or just not produce any more power?
Edited by JT on 19th Jul, 2006. My build thread..
19th Jul, 2006 at 01:32:17pm
the first T2 i got from a R5 specialist, who said it was a good secondhand item and it was OK, and lasted 2 or 3,000 miles of up to 15psi
19th Jul, 2006 at 11:19:27pm
read your tec spec and i get the impresion that the t2 is a lot of work if i hybrid my t3 would i have the best of both world not to much lag and it will last me and yousay that normally hybrid how long would it last the t2 hybrid 6,000 thousand miles maybe?? |
20th Jul, 2006 at 08:08:41am
hybrid turbos are modified normal turbos. they normaly increase the impeller size making a bigger turbo, so a hybrid T3 would be over the top for a mini, but ideal for a 2.0L montego running more boost. a hybrid T2 would be better than a standard T2 and if specified correctly would last many years.
20th Jul, 2006 at 11:16:21pm
So what you been about to much say i got my car running about 180bhp why wouldn't be as good as a t2 |
20th Jul, 2006 at 11:20:29pm
On 20/07/2006 23:16:21 Zeemax Power said:
So what you been about to much say i got my car running about 180bhp why wouldn't be as good as a t2 ???????????????????????????? I've no idea if that was a question, statement or dig! Rus pretty much summed it up - and take at this: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=10194 Some good technical info / discussion in that there post!!!! Edited by turbodave16v on 20th Jul, 2006. On 17th Nov, 2014 Tom Fenton said:
21st Jul, 2006 at 08:39:10am
T2 is still a very good turbo, I think that people saying that they are not last for long are frightening the eventual interested guy.these turbo can last a while on well used car, just let it heating before really use it, and let it cool before to stop your car (it mean two or three miles before to arrive) that's std recommandation for any turbo but you have to practice it really when you are using higher boost.
21st Jul, 2006 at 01:46:30pm
whats the mods to be done to a R5 T2 for running higher boost and longer life?
My build thread..
21st Jul, 2006 at 07:47:52pm
mainly the bearings are upgraded to 360° ones, but if my memory's ok , they are not longer made.
21st Jul, 2006 at 10:54:38pm
Alright sounds like your a big fan of the T2s but say i had my T3 done out what would i gain out of it if i had hybrid and i was running 15psi at 180bhp got any idea compared to say standard and a t2? some one told me when you have them hybrid the turbo becomes more lagy at bottom end but faster at top end cos they bore it out and put bearings in and it spins faster at top and thats what you gain is this right? And i would of thought that keeping the oil cool with water was a bad idea cos mixing maybe thought on the t3 there would be more to bore out as well? any advice whats 1.2 bars in psi ? |
22nd Jul, 2006 at 12:40:23pm
a std T2 will not give you suffisant flow for 180 bhp, which needs about 19lb at 2.2 pressure ratio for an a seri this meaning you'll need about 18 psi on high flow cyl head good cam etc .also the t3 40 trim can't flow this.
22nd Jul, 2006 at 12:59:37pm
I should precise that I was talking about the T2/T25 range, their is a lot of other hybrids turbos for larger capacity engine which are using ported hsg, with different wheel imp thrust BB etc.
22nd Jul, 2006 at 01:10:03pm
fab ,
22nd Jul, 2006 at 01:19:39pm
ooops !! sorry fab just got your pm, ill try ot be more diplomatic.
22nd Jul, 2006 at 01:39:30pm
22nd Jul, 2006 at 01:59:38pm
thanks fab ,appreciate it . did you mean choke line?im sure you did. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
22nd Jul, 2006 at 11:37:24pm
Yes erm this suddenly got my head spinning lads |
23rd Jul, 2006 at 07:29:55am
simply :
23rd Jul, 2006 at 11:05:24am
in your view which would be the ideal t2 turbo the one off the R5T the best and i heard thats two types of set ups one with an apdator plate and a other set up i'm thinking the other set up is a make your own mainfold and just wondering if thats the case ? sounds pretty straight forward when you say it like that ! need to talk simply to me cos i'm just learning but thanks for taking the time mate |
23rd Jul, 2006 at 11:07:46am
I am sorry but your question above is just gibberish........
23rd Jul, 2006 at 11:19:25am
hey peter ,just read your bit on here ,nicely put if i may say so! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
23rd Jul, 2006 at 01:00:56pm
i think what theyre trying to say is a standard t2 off and r5gtt wont cope with 180bhp
24th Jul, 2006 at 10:13:21am
1. Gagrat t2 the best to mod?
