Home > General Chat > Modifying the carb (from Vizards tuning the a series)
confusednewowner
Member #: 854
Fareham, Hampshire
Has anyone on here done any of the work that David Vizard mentions in the tuning the a series book such as grinding bits away to make a smoother flow and a few other bits and bobs that he mentions?
Did you find it made much difference and is it worth it for a turbo carb?
Thanks (if there was a topic already about this then I did try searching for it but found nothing)
T3Tone
Member #: 252
Sunny suffolk
most just carry out mods as per this post. dont believe the cutting and grinding mods will give much at all on a turbo.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=7539
-MINI CLUBMAN 1380 TURBO-
in short....................
forget this as the turbo just bangs the air in
one mod worth doing is removing and fitting a new butterfly the one with out the none return valve in
iain on this forum sells these as a full rebuild carb kit, pm iain
I'd agree, the mods work well on NA cars, but are of minimal benefit on a turbo.
Still I guess every little helps if you have time on your hands.
t3gav
Member #: 229
Gavin@minispares.com
kent
does the t-piece trick use the by-pass hose or should it just be welded up?
jamesfawcett
Member #: 218
Bingley, West Yorkshire
looking forward to reading that 1071 whens it out?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
still waiting on advertising prices Pete *wink*
Alex
AlexF
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Cheers!
AlexF
confusednewowner
Member #: 854
Fareham, Hampshire
Also could somebody tell me for the air filter is it worth spending a lot on say a pipercross viper (ebay probably) or to just get a KN or similar?
What is the reasoning for the manufacturers listing various air filter for different cars can you not just get the air filter from say a 1.4 peugeot and use it on a mini?
Surely the carburettor or fuel injection system can then sort the air/fuel mixture out itself?
(please excuse my ignorance if this is not possible!)
