| Home > Help Needed / General Tech Chat > intercooler / charge cooler advice | |||||||
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
21st Jul, 2006 at 10:39:39pm
i have been given three cosworth intercoolers, two 2wd ones (one of which has been converted to a charge cooler) and 1x 4wd. i notice most people put em at the front up top then cut loads of holes in the bonnet, i was hoping not to do this, can these intercoolers be positioned lower down or will they foul the dizzy ? the outlets have been modified on all so they come straight out rather than one being offset ??
Edited by Richie on 23rd Jul, 2006.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
1300 Posts Member #: 829 Post Whore essex |
21st Jul, 2006 at 11:02:15pm
4WD cooler if fits 1293 Turbo mini
22nd Jul, 2006 at 06:48:35pm
would going for charge cooler be more advantageous than intercooler ? for application to turbo mini (track day car / sunny staurday car)
22nd Jul, 2006 at 09:04:06pm
Forgive me if im wrong, but i'd have thought that a charge cooler dumping heat to the cooling system would require a bigger rad.
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
23rd Jul, 2006 at 12:03:38am
no a charge cooler requires a seperate cooling system "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
23rd Jul, 2006 at 12:48:26am
i have seen one on a dax rush it has a seperate tank and pump system.
23rd Jul, 2006 at 10:39:40am
23rd Jul, 2006 at 11:00:19am
If i was ever going the charge cooler route i would not have the "cooler" part even in the engine bay. I'd run the boost pipes through the bulkhead and mount the cooler tucked up under the dash.
![]() 28 Posts Member #: 1161 Member Somerset |
23rd Jul, 2006 at 03:56:37pm
sorry to hyjack, but would a fiat punto gt intercooler be any good?
23rd Jul, 2006 at 07:49:43pm
luckily for me all the nozzles have been cut and are 90 deg they were for a dax rush with a 4wd escort cossie engine in running a T35 at 20 - 30 psi (i think i heard that right) The lad, who also is getting into the turbo mini scene and will be registering soon !! has got a charge cooler on his rush with the rad at the front.
23rd Jul, 2006 at 10:45:21pm
rite i think i got it me mukka came down and gave me a hand. and the foolowing was learnt !
23rd Jul, 2006 at 11:04:47pm
sh*T looks like its been done already :(
24th Jul, 2006 at 03:49:46am
Not a charge cooler, but a catch tank... Edited by turbodave16v on 24th Jul, 2006. On 17th Nov, 2014 Tom Fenton said:
24th Jul, 2006 at 10:09:25am
but if you were given a bling charge cooler and had the rad and pumps would you use it ?
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
24th Jul, 2006 at 11:01:45am
can someone clarify the difference between the 2wd and 4wd cossie intercooler? I was led to belive they are similar? i know of got a cossie intercooler, but am now not sure which one it is.
24th Jul, 2006 at 04:16:19pm
Found it, as previously posted my mr turbodave
6 Posts Member #: 1156 Junior Member YEovil |
24th Jul, 2006 at 11:28:20pm
Personally I'd use a well thought out intercooler, Charge Coolers can experience massive amounts of heat soak in the water system, especially when queuing up for a run!
Edited by GRSmotorsport on 24th Jul, 2006. Graham
24th Jul, 2006 at 11:46:19pm
Believe me Graham knows his onions...
25th Jul, 2006 at 12:22:50am
what size reservoir would i need for a 2wd cossie (converted to a charge cooler ?) i will be using a fiat shittyshento lol rad, which is same size as metro one but outlets are at one end. this rad is mounted behind grille with two fans on. i was going to put a coolant mix in the water ? is this right or wrong ? the cooler is mounted in my wing, as per the catch tank config on my earlier post.
Edited by Richie on 25th Jul, 2006.
25th Jul, 2006 at 12:40:23am
I'm thinking that a small motorbike rad is more than enough personally... ah - I see Peter is reading, so I'll take a back-seat! LOL On 17th Nov, 2014 Tom Fenton said:
25th Jul, 2006 at 12:43:40am
hahahahaha lads all this feedback is good, dont be afraid to say its shite, but back it up with tech data if poss. i know it works on me mates dax rush and that thing is tuned to bits like 30 psi is rediculous
25th Jul, 2006 at 08:28:31am
I'd be interested in your 4x4 intercooler if you'd like to sell!
25th Jul, 2006 at 08:49:21am
lmao. vegard i will keep you posted, this idea may go belly up as yet , but you gots first dibs Edited by Richie on 25th Jul, 2006.
25th Jul, 2006 at 10:05:06am
sweet lmao, i will post pics of mine v soon i have retro fitted most of the components, it will all be coming off as car goes for paint back end of next week :)
5 Posts Member #: 1172 Junior Member |
26th Jul, 2006 at 12:35:46am
hi guys - new on your forum!
