Home > General Chat > Spark plugs...
Had any experience of these? Price doesnt seem over the top for a good plug.
http://cgi.ebay.co.uk/WRC-CHAMPION-SPARK-P...1QQcmdZViewItem
Also seen them listed on ebay as reduced to 25 a set.
Edited by iain on 25th Jul, 2006.
JT
Member #: 637
Hertfordshire
i got some bosch ones from halfords for £19.99 for my little 998, seem pritty good.
cheers
josh
My build thread..
I think Cossie plugs are 10mm instead of 12mm? In a 300BHP Cossie the Motorcraft plugs are the best.....
nope, they'll fit a mini *smiley* think they just use the 12mm spark plug wrench rather than the 14mm. purely for access though. same on the rs turbo plugs i'm currently running.
I learn something new every day! I've not got any to hand but knew the socket was a different size, expected the thread to be the same! The std cossie and escort plugs are the same according to NGK.
Wether the Cossie race plugs will be to cold for the mini is another matter.
The cossie race plugs are quite suseptable to cold fouling though, which is why the Motorcraft are better upto 300 BHP.
Edit: I think they're AGPR 901C
Edited by Bat on 26th Jul, 2006.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
If you want those plugs run standard Ford cossy plugs (071s iirc).
They are considered much better!
PS I also thought RST plugs fitted but cossy ones were too small!
Alex
AlexF
I run BPR8ESs and they are RST plugs
