Home > A-Series EFI / Injection > Injector Resolution
I've read alot in here about problems with not enough resolution to run big injectors, and still get a good idle. I've found this on the MS forum http://www.msefi.com/forums/viewtopic.php?...=asc&highlight=
and figured it may help? Apologies if you already know of this....*blush*
I've also spotted this..... Same with the router board, this is a higher resolution solution with sequential and COP, with events based on crankshaft degrees instead of time. The router board will probably not adapt to every wheel used on all OEM cars, but for a timing solution that will lead to things like ion sensing which will be implemented in a competent manner.
Gavin:)
Edited by Bat on 30th Jul, 2006.
evolotion
Member #: 83
Glasgow, Scotland
i finally got around to uploading this code and drove around on it all day today, at idle i run a very low pulsewidth and this code helped lots, its the shit.
Denis O'Brien.
