Home > Wanted > MPI Crank Pulley Wanted
This is a wanted ad on behalf of Fab in France, he wants one of my machined pulleys for his car, but uses the MPI type pulley and Micro-Vee belt.
If needs be he will have to send his pulley from France for machining and then sending back, however if anyone in the UK has one up for sale this would work better.
Many Thanks......
A friend of mine in Norway is also after one of these to drive an AC installlation.. So, if anyone got two... :)
Speak to snnoker147 on ebay (MinisBristolMinis). I'm waiting on mine through the post as we speak, £57 posted for a crank and water pump pulley.
Though we have had this discussion before as to whether there is enough room on the end to machine the reluctor.
Still I'll be very interested if it can be done.
Edited by Sprocket on 7th Aug, 2006.
Dont bother with trying to get pulleys from ebay member snnoker147, they guy hasn't a clue. Hes moved premises and aparently thrown a load of gear out. Took him WEEKS to sort out the one i have, collected it today, along with another MPI block again which he had no clue( thought it was an auto and listed as half engine, it didnt have a crank, was used and one of the bores was full of water, Doh, not a clue) Nice bloke though.
Any way heres piccies of the pulley. IS it possible to machine this. My thoughts are that its not, due to the small area and also the ballance drillings close to its perimeter, which before anyone suggests it, these holes are not equally spaced and theres not enough in a quarter of whats been drilled.
I intend to use either a proprietry kit from KAD or Specialist Components or fudge one together my self
Copied this to this topic http://www.turbominis.co.uk/forums/index.php?p=vt&tid=7423
Edited by Sprocket on 23rd Sep, 2006.
Something here's got to fit?
http://www.trigger-wheels.com/
I'm very interested to find out if this can be done aswell!
I need one too! :)
