Home > Help Needed / General Tech Chat > turbo under the car?
beestje007
Member #: 1230
Hello i was wondering if it isn't possible to build the turbo under the car? a little underbody modifications, 4-2-1 manifold, straight to the turbo... it would be nice i think?
Kean
Member #: 341
aka T2clubby
South Staffs
Guy on here has done a similar thing, have a look in show us yours section
beestje007
Member #: 1230
i have been looking in show us yours section but no under the car turbo thing??
Dangerous
Member #: 417
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=8960
Leonard
Member #: 806
Cirencester, Gloucestershire
what engine are you using? because you will have too many pipes if you use a 4-2-1 on an a-series!
beestje007
Member #: 1230
a metro 1275 A+, why? only the exhaust pipe from the 4-2-1 to turbo, the oil and water feeds and return and air. because i will be using a T2, but with this guy, the turbo is far away i would put the turbo in the middle for faster respons. My T2 has water and oil in and outler, but do i have to use the water in/outlet? and why is the oil outlet such a smale hole in comparisasion the the inlet of the oil? thanks
Edited by beestje007 on 31st Aug, 2006.
Kean
Member #: 341
aka T2clubby
South Staffs
What Leonard is saying is that the A-series only has 3 exhaust ports
I think you might have the turbo oil inlet/outles the wrong way round. Outlet is bigger than inlet.
And yes I think you mean 3-2-1 (but that dosent work either) but like an LCB.
Wil
Ric
Member #: 36
Basingstoke
Not hugely practical in this country with the amount of speedbumps we have.
TBH, I'd just stick with a standard turbo conversion and once you have mastered that, move on from there.
beestje007
Member #: 1230
yehh, but it sounds nice, a turbo under the car, ok but with 4-2-1 i meant a spaghetti manifold. WHat do u mean with LCB?
Mini_Andy
Member #: 432
long centre branch basically a stage 1 kit exhaust. like this
http://www.minispares.com/Product.aspx?pid=33346
beestje007
Member #: 1230
a ok thanks, what is ment with a rc40 exhaust? can i fit a selfmade exhaustpipe on that LCB?
Mini_Andy
Member #: 432
its just a type of exhuast
