| Home > Help Needed / General Tech Chat > will auto subframe work? | |||||||
125 Posts Member #: 751 Advanced Member Aberdeen |
7th Sep, 2006 at 09:49:25pm
I am in need of a cheap pre 1976 subframe (twin bolt per side type) to rebuild for my mini and know where i can get a auto sub frame for a decent price. Will this fit the metro turbo engine ok?
7th Sep, 2006 at 09:52:51pm
pm this guy
7th Sep, 2006 at 09:54:53pm
I think its slightly wider, so spacers are needed on the bottom 2 mounts.
7th Sep, 2006 at 10:35:49pm
I used a bit of 1/4" thick plate each side with a couple of holes in, between the engine mounts and sub frame each side Edited by Dangerous on 7th Sep, 2006.
7th Sep, 2006 at 10:47:38pm
I used some spacers, about 4mm each side. I also used a slightly longer gear selector rod and a longer "dog bone" engine steady.
7th Sep, 2006 at 11:48:33pm
On 07/09/2006 22:47:38 Tom Fenton said:
I used some spacers, about 4mm each side. I also used a slightly longer gear selector rod and a longer "dog bone" engine steady. Are the longer gear selector and engine steady available to buy or is fabrication of the origionals needed? Hence would i be better off waiting till i find a standard front subframe as i cannot weld or fabricate etc.. Thanks for all the responses. Dan |
7th Sep, 2006 at 11:49:34pm
Gear selector off a metro, dog bone off an injection mini.
