| Home > Help Needed / General Tech Chat > What are these pistons? | |||||||
21st Sep, 2006 at 11:19:14am
I bought what I was told was a 1380 block and pistons about ten years ago, last night i was looking at it to see what size bowls i could get into the pistons,
21st Sep, 2006 at 12:04:34pm
70.6mm is standard 1275 bore On 26th Oct, 2004 TurboDave16v said:
21st Sep, 2006 at 01:17:13pm
Sorry I was comparing them to a set of std's and typed the wrong figure,
21st Sep, 2006 at 02:33:54pm
is that diameter of the bore, crown or skirt of piston??? On 26th Oct, 2004 TurboDave16v said:
21st Sep, 2006 at 03:09:34pm
crown. On 28th Aug, 2011 Kean said:
21st Sep, 2006 at 03:12:10pm
I make them roughly +60's, allowing for a bit of measuring error etc....
21st Sep, 2006 at 03:21:29pm
well id say 73mm if its the crown you have measured On 26th Oct, 2004 TurboDave16v said:
21st Sep, 2006 at 03:36:55pm
you should measure about 10mm up from the base of the piston on the skirt in the same line as the gudegon pin
AlexF |
21st Sep, 2006 at 03:47:02pm
Also remember the piston is smaller than the bore anyway to alow for running clearance so wont measure exactly stated sizes
21st Sep, 2006 at 04:05:43pm
Well if they are bigger than std,and marked std they could be triumph spitfire? pistons.well they definatly used some triumph pistons to go big bore
21st Sep, 2006 at 04:12:49pm
ok just measured the "A" measurement 73.12mm,
21st Sep, 2006 at 04:18:02pm
On 21/09/2006 16:05:43 Dangerous said:
Well if they are bigger than std,and marked std they could be triumph spitfire? pistons.well they definatly used some triumph pistons to go big bore You mean these? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...:MEWN:IT&ih=016 You would deffo know you had them
Well ok, if the piston measures 73.12 then it is 73.5mm bore and it is a 1380. With my 74mm pistons the bore is actualy 73.88mm with a 0.2mm clearance so the piston is around 73.68mm. I left all the measuring to the machinist, just gave him the pistons, he phoned Omega for the clearance, LOL, he said the guy on the end of the phone never knew they even did a 74mm piston for the A series, must have been a youngster he was soon passed over to an older employee of Omega
21st Sep, 2006 at 06:01:19pm
ok, now i'm at home i've measured the block, just a shad under 73.5mm, and now i've added it all up the "A" measurement is about 11 thou less than the bore and the crown about 15 thou less than the "A" so it stacks up if you allow the measrements are with cheap digital verniers.
21st Sep, 2006 at 06:25:23pm
found out what they are...
21st Sep, 2006 at 06:33:45pm
21st Sep, 2006 at 06:39:12pm
Ah right that clears that up then,
21st Sep, 2006 at 06:45:45pm
On 21/09/2006 18:33:45 Bat said:
Hi, STD means standard size for that bore, you could still theoretically get +0.020 ect for the 73.5mm bore. Cheers, Gavin :) ![]() ![]() ![]()
21st Sep, 2006 at 06:47:02pm
here they are for any one interested.
