| Home > General Chat > pre-verto stuff vs verto stuff | |||||||
138 Posts Member #: 138 Advanced Member |
9th Oct, 2006 at 07:37:46pm
Which is better for holding the power?
9th Oct, 2006 at 07:41:56pm
all will be answered with a search.
10th Oct, 2006 at 01:36:29am
The verto is a more modern design and should work better.
809 Posts Member #: 224 Post Whore Katy TEXAS |
10th Oct, 2006 at 09:41:16am
Turbodave is developing an uprated/ultimate verto at the moment.
Edited by Brocky on 10th Oct, 2006. BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
10th Oct, 2006 at 10:51:10am
Once I found a cover strong enough....I never had any clutch issues, other than the paddle ate the flywheel and cover during use.
10th Oct, 2006 at 10:54:26am
Stevie,
Edited by Paul S on 10th Oct, 2006. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
10th Oct, 2006 at 11:19:09am
Hey Axel,
10th Oct, 2006 at 11:20:57am
Brocky,
10th Oct, 2006 at 11:24:54am
10th Oct, 2006 at 11:26:59am
10th Oct, 2006 at 01:12:17pm
Going back to original question,the best clutch for holding power is th pre-verto hands down.
Edited by matty on 11th Oct, 2006. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
10th Oct, 2006 at 01:19:35pm
Axel,
10th Oct, 2006 at 09:27:15pm
On 10th of Oct at 10:54am Axel said:
Stevie, I'm hoping to stick with the verto for my mild 998 turbo. Where did you find this strong cover? Could you find it again? Was it one of these with 0.090" fingers and a ring around the studs: ![]() Cover was a fluke. It was a re-con Balco unit for a 1000cc Mini. I had tried 2 genuine Rover turbo covers, as well as the original one that came with the base engine I used. None would take any boost at all. One was even out of balance !!! I tried a couple of other used 1000cc covers I had from other engines, one wasnt bad, the other no better than the turbo covers. Then I hunted through a local motor factors, basically jumping/pushing my weight on the fingers ( via the cup ) of all the covers they had in stock. I picked the one that took the most effort to operate. Some would literally operate under my own weight. The one I ended up with needed me to jump on it to operate it. As its still in the car, its been a while since I seen it. But Im pretty sure it had the rivets with the steel ring around them as you picture. I know many people havent had success with a Verto....but when I read the torque ratings of the pre-verto stuff, no way was I going to try one. I can only guess at how much power I was making, but I dont think circa 180+bhp would be far off the mark. Probably excessive fuelling, T3 and 20psi, and dizzy welded around 26deg I think. 7.5:1 CR, 4 star petrol and a little crude water/meth system, SW5 cam, and Swiftune head. Its enough power/torque to have major traction issues below 70-80mph, and in the wet, every gear. I'll maybe get my engine crane back this week, and start stripping my car, and get some pics, and perhaps try to measure pedal effort if nothing else. Edited by stevieturbo on 10th Oct, 2006. 9.85 @ 145mph
11th Oct, 2006 at 07:59:13pm
On 10th of Oct at 01:19pm Brocky said:
Axel, http://www.turbominis.co.uk/_photos/random...os/425/2761.jpg http://www.turbominis.co.uk/_photos/random...os/425/2762.jpg Finger thickness = 2.38 ave. Matty, couldn't agree more. Cheers Brocky Well, that's the thickest yet at 0.094", but according to some old thread I read some time ago will still only handle around 90 ftlbs. Looks the same as the Sachs one above but with some red paint. Edited by Paul S on 11th Oct, 2006. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
11th Oct, 2006 at 08:18:36pm
Sounds like its all down to the luck of the draw as to the torque capability by the sound of things, may be a factor tolerance ting
Edited by Brocky on 11th Oct, 2006. BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
11th Oct, 2006 at 09:03:24pm
i think a lot of it comes down to the installed hieght, the same as the pre verto type , the supports on the flywheel may need to be machined to get the spring flat. i definately found this with the dual spring verto i made.
