Home > General Chat > astra GTE dash
mic
Member #: 1271
anyone wired one of these up before on a mini? i have the wiring colours sorted but not sure how to calibrate/wire up speedo part, i assume theres a way (without dropping an astra engine in) but not sure
mic
www.retromods.co.uk
Dangerous
Member #: 417
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=5837
You will need the speed sensor off the gear box, and connect it all up to the Mini speedo drive or cable.
Once you've got it working the calibration is dead easy with this gizmo, I know it's for bikes but the universal one should do the job... http://www.speedohealer.com/eng/intro.htm
