| Home > Help Needed / General Tech Chat > new engine smoking | |||||||
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
18th Oct, 2006 at 07:50:57pm
hi ive built an engine for turbo use, but am running n/a for now with hif44 and lcb. the engine has had a rebore, new accralite pistons and rings, new bearings, duplex chain and phase2 camshaft, but is still running a shite fairly worn head.
25 Posts Member #: 1304 Member Ireland |
18th Oct, 2006 at 07:55:16pm
Valve guides or steam oil seals would cause it to smoke sometimes but not all the time depending on how hot the oil is.
Quiet, can you hear it rusting? |
18th Oct, 2006 at 07:56:52pm
18th Oct, 2006 at 07:56:56pm
that might just be coincidence with me turning right, but it always does it when ive slowed down and turned right off the main road and put my foot down again.
18th Oct, 2006 at 08:00:29pm
A diesel leak would make black smoke but petrol would just stink.
18th Oct, 2006 at 08:02:44pm
not really. it can just start when your driving steadily, then stop again a minute or so later.
18th Oct, 2006 at 08:17:55pm
Odd one then,
Edited by Frisco on 18th Oct, 2006. Quiet, can you hear it rusting? |
18th Oct, 2006 at 08:22:17pm
i'll try the breather and let you all know
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
18th Oct, 2006 at 11:23:07pm
I had a similar problem with a fresh built engine last year, really smoked when hard cornering, turned out I had overfilled with the oil so when cornering at speed the timing cover breather connected to the carb was drawing oil up, just drained a little oil off and it cured the problem.
19th Oct, 2006 at 05:31:56pm
yeah must be a similar thing shaneyboy i disconnected the breather and it stopped. i can stop shitting myself now its not a ring or some other major fuck up. cheers guys
19th Oct, 2006 at 05:43:56pm
I know how you feel, as soon as i noticed the smoke on mine, i instantly thought, "what piston didI not align the rings correctly?" was thinking I was going to have to rip the enine out to sort it (and this was a couple of days before L2B run, nothing quite as nice as a tight deadline) Glad I checked a few small thing first before my usual bull in a china shop attitude. Hope you get it sorted,
19th Oct, 2006 at 08:44:44pm
could this problem we've had be due to the removal of that piece in the timing cover, to allow clearance for the duplex chain? I was thinking when i removed it that it must be there for a reason.
19th Oct, 2006 at 08:46:41pm
I never removed mine, I just peined out the area that fou7led the gear with a paralel tip punch, my prob was simply due to to much oil.
