| Home > Technical Chat > VNT turbochargers and control | |||||||
223 Posts Member #: 598 Senior Member Gaol |
2nd Nov, 2006 at 08:58:42pm
Hi there guys
On 5th of Sep, 2006 at 05:47pm mini13 said:
I reckon if his brains were gunpowder he couldn't blow his own hat off... |
2nd Nov, 2006 at 09:09:47pm
thght i'd stick the stuff from the other thread here for anyone searching.
Edited by Joe C on 2nd Nov, 2006. On 28th Aug, 2011 Kean said:
2nd Nov, 2006 at 09:42:38pm
one thing that just occured is it may be worth running the actuator via a lever system so the sensitivity of the vanes can be adjusted as there sould be no wastegate "cracking" issues. On 28th Aug, 2011 Kean said:
2nd Nov, 2006 at 09:49:06pm
Edited by Bat on 2nd Nov, 2006. VEMs Authorised Installer / Re-seller. K head kits now available!
2nd Nov, 2006 at 09:55:37pm
VNT vanes open and close causing the gas speed powering the turbine to change, opening them causes the gas speed to drop slowing the turbine etc.
2nd Nov, 2006 at 10:01:25pm
3rd Nov, 2006 at 12:18:35pm
i disagree about the vanes Bat,
3rd Nov, 2006 at 02:28:12pm
j , i think that would work well , its what i ws ging to do before i went the gt17 route , i imagine you have thuoght of this but you can also change the length of the arm to the vnt to change angular deflection per psi of boost ,and another thing i thought of ,was to put the diaphragm at something other than at a right angle to the arm , so that it would create a varying level of deflection per pound of boost ,and create a curve on the graph of mm /psi.
3rd Nov, 2006 at 02:31:28pm
hi there is some vnt's that are using boost to control the vanes, just use the proper one on the vnt you have, ex renault espace 2.1 dt vnt, fiat croma tdi vnt, dodge 2.2 vnt..
3rd Nov, 2006 at 11:10:23pm
Fab,.... if you could take the pic of Vnts turbos to suit the A sreries engine
3rd Nov, 2006 at 11:25:03pm
^^^^ LOL ^^^^^ On 17th Nov, 2014 Tom Fenton said:
3rd Nov, 2006 at 11:30:08pm
well moneys been a problem for me dave at the mo..
4th Nov, 2006 at 12:07:04am
If money's a problem, maybe it's time to start selling the thirty+ 1275/turbo motors you have in storage! LOL! On 17th Nov, 2014 Tom Fenton said:
4th Nov, 2006 at 12:28:08am
Benross,
4th Nov, 2006 at 12:33:48am
about the imp,
4th Nov, 2006 at 01:45:36am
yes it may be time dave ...lol!!
4th Nov, 2006 at 07:24:17am
4th Nov, 2006 at 09:36:22am
Hi fab,
7th Nov, 2006 at 10:44:45pm
I took some times as I never look for this but if you engine see 15 psi and so blow them to your turbocharger , then how many do you want it to put on them? an other 15 psi? this turbo will well be geared by a 22 turbine wheel, but his compressor need to blow a small amout of air if 15 psi is allready supplied by the charger then you would need a smaller compressor as you'll be completely inefficienty if not under surge. Perhaps I missed something but you should substract from your compressor flow the charger flow, then you'll find the right flow/pressure
7th Nov, 2006 at 10:55:43pm
a last question
8th Nov, 2006 at 10:17:13am
no faB mon ami the turbo would be acting like my big turbo on the tvr , it would blow into the supercharger , like my big turbo blew into the small turbo , ,so its airflow must supply engine air flow times a bar ( very roughly put !),. :)
8th Nov, 2006 at 10:44:01am
7psi at 5700! That must be interesting to drive but top marks robert for trying these things out!
8th Nov, 2006 at 10:47:54am
yes,
8th Nov, 2006 at 10:48:44am
oh god tom , its such a slug lol, j , if you want to see the twin staged setup its on the tvr progress on show us yours section . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
8th Nov, 2006 at 01:47:52pm
Right the system i am going to use goes like this -
this was sort of expected thuogh and is part of the experiment..
