Home > General Chat > turbo pistons
jimmy
Member #: 829
essex
what would you said these can handle on boost ??? upto 10lb or a little more like 14lb ?? http://www.minispares.com/Product.aspx?pid=33584
Edited by jimmy on 6th Nov, 2006.
1293 Turbo mini
That all depends on how much you take out of the head. On 9.4:1 and intercooled with mapped ignition you should get 10psi in there no problem. You may get a bit more if your lucky.... I wouldn't think the piston would be the limiting factor.
Edited by Bat on 6th Nov, 2006.
Pinking is more likey to be your limiting factor!
When they say 9.4:1 CR I think there just refering to dish size e.g standard 11cc.
The Minispares Mega pistons are supposed to be excellent. I can't see you having any trouble with your proposed 14psi.
Phil. *smiley*
turbo hogster
Member #: 178
stowmaket suffolk
i ran 14psi on 9.4 cr with intercooler but 12 was a safe bet.
with supurb of boost econamy and pickup which you dont get with low cr.
but mine will change this year.
