Home > Help Needed / General Tech Chat > turbo mini top speed
turbotitch
Member #: 1350
what would a standard mini turbo do top end?? and 0-60??
depends on a lot of things
a worn out 20 odd year old engine
wont be too fast if it holds togeather
a fully tuned well set up engine with the right gearing will take you to a shade over 140 MPH
0 TO 60 in under 3.5 seconds
MarkGTT
Member #: 1194
Shropshire.
bit of an open ended question.. depends on many factors, e.g wheel size, weight of car, fuel etc etc.
Edited by MarkGTT on 7th Nov, 2006.
And the amount of money you are prepared to spend!
Allow at least £3,000 to get started with something half decent.
Assuming a std metro engine spec (in good condition!!! and well setup!!!) and 13" wheels, the performance figures for the ERA turbo should be pretty close.
according to this link 0-60 7.8sec, top speed 115mph,
http://www.miniresource.com/performance.php
Edited by Joe C on 7th Nov, 2006.
ive had 119 out of mine, it may of done a bit more, but i got scared
turbotitch
Member #: 1350
is yours standard?? its a good engine and ill be running 12" wheels
oh no, far from it
its running a 3.2 fd and 10"ers
i think you'll find most people gear their cars for about 120 just because this gives the best all round performance, with a 2.7 diff and 13" wheels and 200 bhp you could get silly speeds.
I personally think about the 120mph is the top speed achieveable in a mini, purely for aerodynamic reasons.
Ben H
Member #: 184
Melton Mowbray, Pie Country
This has been covered before a bit. I did some rough calc on this last time check out this thread
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=6647
http://www.twin-turbo.co.uk
interesting calcs there Ben!
the way the power needed ramps quickly seems to fit with the speeds i've heard of. i think 120 is a little consevative but 130 is about as much as it's likeley to see and Bens figure seem to support this.
I had my car pulling a 7500rpm limit ( Crane ignition ) in 4th gear, 3.1 diff with 165/65x13 NCT2 Goodyears.
Thats a tad more than 120mph *wink*
Admittedly that particular time was downhill, but over quite a short distance before coming to a roundabout. the actual stretch of road is about 0.75 miles between 2 roundabouts. Up a steep hill, then down again.
On the flat, it would easily pull 7000rpm in around 0.75 miles ( another road *happy* )
It would pull beyond 7000 in 4th on the flat, although I never tried it very often.
I once raced an Escort Cossie ( new cars back then ) once over a distance of about 2 miles up the motorway lol...I just kept pulling and pulling...was quite funny.
He was amazed....although not so amused when I asked him what was wrong with his car afterwards lol
AHEM!!!
AllanMcD
Member #: 414
Dalbeattie Scotland
120 mph you must be talking about the 1/4 mile
Allan
http://www.rabdunn.co.uk/
johnK
Member #: 690
Norfolk
with 163bhp my car will lose the battle with the air at 132mph- according to very accurate prediction software - what miniwilliams or jimsters would do on "long" gearing is more than your underpants could stand in a Mini!
If Carling made Mini engines
JT
Member #: 637
Hertfordshire
am i right in thinking 0-60 times are limited to grip? especialy with smaller wheels?
My build thread..
carl talbot
Member #: 1323
I took the KAD demo car round Combe on a mini day many years past , it was easily the quickest car there , that read 125 on speedo in 4th but wouldn't pull that in 5th [ dont know what diff they were running , or if the speedo was anywhere accurate ] but that gives good indication of brick like airo. !!
t3gav
Member #: 229
Gavin@minispares.com
kent
i'm sure jf mentioned 130mph+ in his mini :)
j_d_jag_mini
Member #: 979
Im not sure what mine does in MPH but i know it can wind out to 200km/h maxed out and running 12psi on 13" wheels with 2.9 diff. It very scarey car tho when i get over 160 ! (which i think about 100mph?)
I remember it doing 140km/h in third when i watched it on dyno.
1975 MkIII Morris Mini 1300 Turbo, 100bhp...if only it could run long enough to drive it legally!
