Home > General Chat > carb heat shields( reproduction) need measurments from people
nogin
Member #: 487
westbury, wiltshire
there has been a delay on the heat shields, need to modify the mould slightly, i need the measurments from the float bowl to the bulk head, as mine is pretty tight i need to find out if others are the same, i suspect so cheers
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
They are always tight (too tight) if the top-steady isn't lengthened.
nogin
Member #: 487
westbury, wiltshire
well thats why im trying to get around it in a way so people who dont have adjustable stuff dont need them but cheers for the comment, to tight is the word for the original one
i also make things
I think solving that problem could make the heat shield less effective by being closer to the float bowl....
nogin
Member #: 487
westbury, wiltshire
ye i understand this point tottaly, i thought this to but a heat shield is better then none at all, plus i am trying to make it so every one can use it, eg it does have some adjustment on it
i also make things
I'd say adjustable is the way to go. Hope someone can help you out with the measurements.
