Home > General Chat > holes in the bonnet
lil stu
Member #: 837
rugby
alright guys what is the best way of cutting holes into the
front of my standard bonnet ive mounted a sierra intercooler
just behind it so need the air flow
cheers stu
Use a hole cutter. I know it sounds obvious, but the one you want is like a drum with teeth on the edge and a 6mm pilot drill in the middle.
or if you can get hold of a hole punch, it's two parts that wind together with a bolt and cut a hole ( unsuprisingly) only any good on flat sheeet tho.
lil stu
Member #: 837
rugby
cheers lads i did have a feelin you would say use that saw type cutter just wanted to
check before i butchered it
cheers stu
When using the hole cutter, get someone to spray water onto the area your cutting, prevents the paint from getting too hot and bubbling, you don't need to respray it just carefully touch in the edge with a small brush. *wink*
nother thing put masking tape on the surface to stop the cutter skipping ,and i used a starret hole cutter ,keep rpm up and dont force it .
Turbo Shed
Member #: 30
Epsom, Surrey
i used a pickaxe. fast and effective
minimark
Member #: 19
newcastle
your the man !!
as robert says starret cuter 51mm best size
masking tape the work area up
this saves burning the paint
heres mine finished off with 6mm copper wire sheathing split
hope this inspires you
lil stu
Member #: 837
rugby
why is 51mm the best size?
i was gonna use a smaller one and just have more holes.
kind of like turbo phils
stu
this is just my opinion stu
these 4 x 51mm holes reduced the engine block water temp by 10 deg on a hot summers day
you want a large surface area, there is not much room under the bonnet to accomadate this with the stays etc.... this is the best in my humble opinion
kinda borrowed from john flan in 1997 ish......*laughing*
each to their own :)
wow! those 4 hole's had that much effect, now theres a good cheap mod!
JT
Member #: 637
Hertfordshire
im going to have the holes go all the way along the intercooler, so that the whole thing is getting cool air onto it!
My build thread..
Nick
Member #: 154
Midlands
i did the same on mine when i fitted my first intercooler back when it was a roundnose with a big ugly chavvy bonnet.
bud, you garage looks jut like mine, even the same garage door!
except my garage is full of shit.
yes more holes if you can get them in!
"the trap not to fall into".... is........ not crossing the borderline into CHAV! territory....lol *laughing*
i think you did budd666, but you corrected it
JT
Member #: 637
Hertfordshire
looking at pics im going to do somthing similar to alex's frog mini, same sort of pattern and it should get the whole intercooler with cool air.
di you do your own bonnet benross or did you buy it? looks differnt!!
cheers
josh
My build thread..
Nick
Member #: 154
Midlands
Yeah i know it was chavtastic....I can't take full responsibilty though. I had a wolfie incident which wrote off my standard bonnet, all i could get at short notice was that one for a tenner. :$:$:$
Mini13, yours sounds just like mine then, i was standing on all the shit to be able to take that photo, lol *happy*
Edited by Nick on 10th Nov, 2006.
josh all done by yours truley
notice the M3 stainless cap heads in the bonnets vents
it looks engineered not chaved!
budd.....LOL *blush* *laughing*
Edited by BENROSS on 10th Nov, 2006.
Do you think i should mirror mine then for extra cooling?
heres what some 72mm holes look like .
now that i like!
you can see somthing behind it proving its not just for show. plus on an otherwise std bonnet it looks class.
ruabadfish2
Member #: 1114
Georgia
i like the look of that too...but how sturdy is it?? I can only imagine being out and public, and some chic screaming she wants her picture taken next to it, plops her big 'ol arse up and there goes your hood. *frown* Any kind of bracing behind it?
1994 Rover Mini
LOL maybe you need a bg sticker...
No fat chicks!
1976_mini
Member #: 259
grays, essex
lol *crying*
it may b small but it purfectly formed
http://photobucket.com/albums/v340/1976_mi...roject%20turbo/
