| Home > Help Needed / General Tech Chat > Is this the right turbo rebuild kit? | |||||||
11th Nov, 2006 at 12:51:44pm
unfortunately my turbo shaft has gone a bit wobbly this year, i presume this is the result of me not running a dump valve
11th Nov, 2006 at 12:59:45pm
Hi Nic
11th Nov, 2006 at 01:10:26pm
it has considerably more play than i would like (up and down), and i know that it has got worse over the year
11th Nov, 2006 at 01:37:14pm
Nic I think you're turbo is overspinning, at 18 psi you should have something like 160/170 bhp and a bog std r5 unit it is out of breath and revs.
11th Nov, 2006 at 01:39:26pm
11th Nov, 2006 at 02:03:35pm
dont think nic's turbo is a bog std R5 unit though.
11th Nov, 2006 at 02:04:24pm
std r5unit isn't efficient over 15 psi,and out of breath at 150 bhp, evidently you can overspin it but it'll wear quicly and will charge inefficiently |
11th Nov, 2006 at 02:07:11pm
ps, the kit i can get hold of is supplied to turbotechnics so cant be of bad quality!!
12th Nov, 2006 at 01:57:53pm
don't know if you are familiar with turbo dismantling but don't forget to mark the wheels alignment BEFORE to disassemble , if you're not doing the balance will be wasted |
PM me
