| Home > General Chat > Dump Valves | |||||||
180 Posts Member #: 591 Advanced Member Rugeley, Midlands, England |
21st Nov, 2006 at 07:38:57pm
Been researching some parts for my turbo build which is about to commense shortly. There are many different types of dump valves that i have found. BOV believe these are blow off dump valves the most simple, sequential dump valves and recirc dump valves, what is the differences, advantages and disadvantages of these dump valves advise and comments please what you are running and also what else is on the market like trick jap technology that NASA probs doesnt know about8)
21st Nov, 2006 at 07:48:18pm
to be honest i dont think fitting a £300 hks will give any benefit over a £30 one |
21st Nov, 2006 at 07:53:37pm
First point to note is that not all dump valves will work with an SU carb.
21st Nov, 2006 at 07:57:29pm
Edited by Bat on 21st Nov, 2006. VEMs Authorised Installer / Re-seller. K head kits now available!
21st Nov, 2006 at 08:06:11pm
DONT by a bailey one, it will end up going wrong on you thanks to fuel contamination with the seal |
![]() 549 Posts Member #: 1347 Post Whore Croydon (South London) |
21st Nov, 2006 at 08:06:57pm
From what little i know i dont think theres much point running a dump valve with anything smaller than a t4. People say it keeps the turbo spinning but ive heard arguments that without one pickup is actually quicker between gear changes etc. I suppose if you want that typical whoooosh sound then go for it, personally id much rather hear a turbo chatter its nutts off when it stalls |
21st Nov, 2006 at 08:30:58pm
On 21st of Nov, 2006 at 08:06pm AL said:
personally id much rather hear a turbo chatter its nutts off when it stalls And then risk the turbine blades disintegrating and being ingested and wiping out valves/pistons/gearbox????????? A dump valve is a MUST on our minis _IF_ the poppet valve in the carb butterfly has been removed, to prevent turbine stall. I have seen a few T2's with snapped shafts from turbine stall, it DOES happen........
21st Nov, 2006 at 08:42:22pm
How much boost were they running to snap a shaft? |
21st Nov, 2006 at 09:45:21pm
Its not the boost levels that kill the compressor, its surge. Running without any sort of pressure relief IE poppet or dump valve, will force the compressor into surge. This surge generates vibrations in the shaft causing the retaining nut to come loose after prolonged time. The impellor then walks forward on the shaft and hits the shroud. At 29,000rpm this is not good. White metal swarf is ingested by the engine, which, again is not good.
Edited by Sprocket on 21st Nov, 2006. On 26th Oct, 2004 TurboDave16v said:
21st Nov, 2006 at 09:58:39pm
You say that its not boost that kills turbos but if you run higher boost doesnt the turbo spin faster? Thus the force on the shaft will be greater when the turbo stalls making failure as descibed abouve occur earlier? Bear with me im still learning Edited by AL on 21st Nov, 2006. |
223 Posts Member #: 598 Senior Member Gaol |
21st Nov, 2006 at 10:16:58pm
surge also causes large loading on the thrust bearing in the turbocharger, again NOT good!
On 5th of Sep, 2006 at 05:47pm mini13 said:
I reckon if his brains were gunpowder he couldn't blow his own hat off... |
21st Nov, 2006 at 10:50:40pm
Assuming no d valve etc... Increasing the boost on the same turbo, depending on the increase will push the compressor into surge much sooner even during normal operating conditions. Thats why you need to select the correct size compressor A/R. There are compressor maps available to plot the operating conditins, where the center of these are usualy 75%, where you should aim to keep it. The surge line is also plotted on these. The further away from this the better. Running without a dump valve WILL push the compressor into surge, that is what the 'chatter' noise is. Surge is the effect of the discharge pressure overcoming the discharge capebilities of the compressor causing a back flow through the eye of the compressor while its still spinning. Once the compressor has recovered, if the conditions have not changed, it will happen all over again. This happens several times a second. It is this that kills the compressor. And yes shafts have been know to snap because of this. Once again surge causes stress fracturing of the shaft or the impellor exploding because of the micro vibratation generated. Working in London at the mo replacing a compressor on a centrafugal chiller that has an impellor 18" in diameter, spins at 18,000rpm. The impellor worked loose due to surge, walked forward on the shaft hit the shroud. The impellor exploded into two, grabbed and sheared the high speed shaft in two, taking with it the 414KW 415volt motor. £250,000 worth of damage and its still in warranty. Its probibly the biggest electric supercharger you will ever see. Pictures to follow cos i think some may be interested. On 26th Oct, 2004 TurboDave16v said:
21st Nov, 2006 at 11:00:16pm
hmmmm maybe a dumpvalve then. But would have to be a recirculating one jus to keep me sane |
22nd Nov, 2006 at 05:47:51pm
Have seen many turbo minis with the dump valve fitted to the plenum chamber but has any one tried different locations to mount a dump valve, eg closer to the turbo, why is it not mounted close to the turbo as i would of thought that the pressure down stream of the dump valve would also cause the turbo to stall, heard the best place to mount a dump valve is as close to the intercooler on the carb side as possible.
22nd Nov, 2006 at 06:01:51pm
I thought it had to be as close to the butterfly as possible, hence in the plenum is the usual place. Not sure why thats just what i heard. |
22nd Nov, 2006 at 06:38:59pm
Dump valves on minis seem to make more turbo lag, i have a BOV only cos i got it cheep and want people to know the little mini behind then has a turbo, it's about all there are good for on minis. Best 1/4 mile 13.2 seconds @116 mph
22nd Nov, 2006 at 09:03:30pm
This is most probibly the biggest electric supercharger you will ever see!!
22nd Nov, 2006 at 09:06:28pm
Ouch!!!! What is one of those used for then? |
22nd Nov, 2006 at 09:15:13pm
Im guessing its for some sort of air conditioning system?
22nd Nov, 2006 at 09:26:36pm
Indeed it is a centrafugal refrigerating machine.
23rd Nov, 2006 at 09:13:13pm
your right you do need a dump valve on big turbos, but on any thing around are sizes or smaller there don't really help. Best 1/4 mile 13.2 seconds @116 mph
23rd Nov, 2006 at 09:35:44pm
Edited by Nic on 23rd Nov, 2006. |
23rd Nov, 2006 at 09:51:41pm
LOL brill comment! Best 1/4 mile 13.2 seconds @116 mph
23rd Nov, 2006 at 10:26:53pm
ha ha yeh
23rd Nov, 2006 at 10:51:32pm
well ive been needing one for the supercharger setup, and ive just got one like this for the steal of the century at £10 brand new including postage!
