| Home > Help Needed / General Tech Chat > Injection Idle Valve and Turbo | |||||||
27th Nov, 2006 at 10:40:48pm
Any reason why i cant use one of the stepper valves as fitted to most multipoint injection Rovers in an injection turbo application or will i have to resort to the throttle stepper On 26th Oct, 2004 TurboDave16v said:
27th Nov, 2006 at 11:10:10pm
If an ecu can control it, dont see why not. A stepper valve should offer better control. 9.85 @ 145mph
27th Nov, 2006 at 11:49:25pm
I was thinking about this...
27th Nov, 2006 at 11:57:13pm
never seen one myself but can say with about 95% cartaintly they do indeed use the same motors as the MPi minis. jsut about every rover running any verion of mems uses the same idle motor(all have the same 5-pin electrical connector), allbeit in different housings depending on application.
28th Nov, 2006 at 06:36:41pm
On 27th of Nov, 2006 at 11:49pm TurboDave said:
I was thinking about this... Is there any chance you can do some research and see what ISCV rover used on the last of the Rover 800 /600 turbo's - basically the dizzyless ones, as these had the closest MEMS system to the MPi mini... Basically - I'm wondering if the 'dizzyless' rover turbo's used the same ISCV as the MPi's... :) Research already done mate
The late 600/800 turbos namely 95 onwards still use the throttle stepper motor attatched to the throttle body. The only reason im asking this is that this throttle body is like 58mm. I need to get this down but still want to keep the idle control the same kind of configuration to the Rovers, however that is, valve or motor. The connector plugs are the same and both work the same. Looking at the 48mm ally TB with the valve, which, incidently you can get in unipolar, a la MPi Mini or bipolar item off, i think the honda engines so suits the aftermarket ecu's On 26th Oct, 2004 TurboDave16v said:
194 Posts Member #: 1297 Advanced Member Sunny Stockport |
28th Nov, 2006 at 11:17:08pm
Check out item # 290056166312 on ebay. Bought one myself a couple of weeks ago for my Emerald ecu equipped turbo FI setup and it works a treat. Standard 5 pin Rover type, Minispares sell them for over a 100 quid.... |
29th Nov, 2006 at 12:22:26am
Now THAT is usefull; especially given how problematic they are.
29th Nov, 2006 at 10:05:20am
so how do these ones work, anyone got any other photo's of them?? Do they open the butterfly, or do they have there own valve in them? Team www.sheepspeed.com Racing
29th Nov, 2006 at 03:44:39pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=10807 On 17th Nov, 2014 Tom Fenton said:
29th Nov, 2006 at 09:36:25pm
On 28th of Nov, 2006 at 11:17pm neilj1678 said:
Check out item # 290056166312 on ebay. Bought one myself a couple of weeks ago for my Emerald ecu equipped turbo FI setup and it works a treat. Standard 5 pin Rover type, Minispares sell them for over a 100 quid.... I think thats where i got mine, the one i took apart in the post above. Any way. That is top info, job sorted. It shal now be Thanks mate
