Home > Technical Chat > Frying a gray pressure plate & modded back plate on 12 psi of boost
Frying a gray pressure plate & modded back plate on only
12 to 13 psi of boost! when the engines working hard
my 1380 Turbo motor is placing some very large bananas out
so its a double gray next!!
whats the horse power the above spec can cope with ?
the single gray and modded back plate per Turbo Daves spec
it's because your'e car a big lardy fucker steve,
Brocky
Member #: 224
Katy TEXAS
Now now jealousy is terrible thing...lol
Isn't mini williams slipping a double grey?
turbo hogster
Member #: 178
stowmaket suffolk
both me and t3tone are running a grey with no probs he has got 180 bannanas so you should be ok.
Kean
Member #: 341
aka T2clubby
South Staffs
Im currently running a grey, modded plate and putting 165llbft through with no probs.... how does the spring sit when its assembled Steve?
andeh
Member #: 97
Near Daventry, midlands
is the spring flat when assembled? I've never seen a clutch setup be right from new parts, they always need to be machined.
i too am running a grey with an organic race rally plate with no problemos
what flywheel and back pate are you running?
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
Benross
which cam are you using?
when you are talking about machined, flat or moded?
is it machined for correct heigh to be flat , machined to be flat then leave what Dave recommend to compensate distortion, or just machined from 22...to 21...??
t2 clubby 165lb thru a grey is good! what's moded in your palte?
how did you set your?
Kean
Member #: 341
aka T2clubby
South Staffs
Fab, mine is machined to 23.5mm so that the spring sits flat when assembled, before this it was slipping at only 140ish llbft..... I'm expecting it to slip again when I next up the power...
Well the flywheels kindley off of fast carl and the back plates kindley off of Vegard both lightend and ballanced
ap race plate
the back plates been fly cut perfect ! off the pillars 1.6mm
three straps and machined pillars to take into consideration the lightning the works just fine!!!
its simpley too much Torque! *surprised*
and yes carl ...lol its a lard fooker *laughing*
Fab its a phase 2 cam with my trick head *wink*
clubby the spring sits perfet to the though!
and its a nice pedal
anyway more to come on mapped ignition shortley
Edited by BENROSS on 30th Nov, 2006.
Nick
Member #: 154
Midlands
yup, me and T2 clubby both got our backplates machined at the same time as his was slipping so we modded them as per dave's guide on the MM site i think it was, lugs down to 23.5mm and the spring sits nice and flat. only using 2 driving straps and a single grey with one of these plates http://www.minispares.com/Product.aspx?pid=38317
both of us were running 165lb/ft at avon and had no clutch issues.
As you say ben you've either got too much torque for a single grey, or you've been riding the clutch like a granny...lol *laughing*
Hmmm - if you're using three straps, then you need around another 0.7/0.8mm off the lugs to take this into account. 23.5mm works for two (six total) straps. If - for whatever reason - you want to run three straps, then it needs more taking off.
Personally - I'd just run two straps.
I also assume you're running the AP Rally Plate, with the dark grey, not the light brown friction lining?
However - this is not too suprising in reality; a 1380 makes more curly-wurlies than a nat-asp. Add a turbo to it and it multiplies to this already increased curly-wurly factor to make a shed load more curly-wurlies; And it's curly-wurlies, not bananas that will find the limit of a clutch.
Edited by turbodave16v on 1st Dec, 2006.
turbo hogster
Member #: 178
stowmaket suffolk
i used to love curley wurleys as a kid i love them even more now ive got a 1380 turbo lol.
Dangerous
Member #: 417
I noticed when I ground Wolfies lugs down that the nearly new backplate was approx .010"concave ,if viewed from the lug side.
Checked by standing it on the lugs on a surface table and running a clock underneath.
Don't know how much effect that would have on the grip level,but I think it distorts due to the heat of it slipping
Edited by Dangerous on 1st Dec, 2006.
to be honest
this motors producing some large numbers
this is the reason
will find out how much a shade later on
fab
Member #: 100
Paris' suburb
i have "analysed" a 1380 phase2 addicted with a st3 head (mintec flow chart) together with a 0.75 nozzle (3000 boost treeshold) , and it calc some 182 curley at 4000....
