| Home > Help Needed / General Tech Chat > MPI Front Subframe Swap!!! | |||||||
332 Posts Member #: 483 Senior Member Merthyr Tydfil |
29th Dec, 2006 at 09:48:49pm
Hi all,
30th Dec, 2006 at 01:23:54am
Change the front frame for MOT????!!!!!???
30th Dec, 2006 at 10:35:47am
30th Dec, 2006 at 06:06:44pm
Yes the subframe has rusted quite badly, and it has failed on the mot.
30th Dec, 2006 at 06:09:01pm
In order to get a front mounted rad in the MPi's they changed the block, alternator, oil system, front panel, no dizzy, quite a lot of stuff. Just changing the subframe won't allow you to fit the front rad.
30th Dec, 2006 at 06:28:20pm
Ok cheers, Thats that out the pan then.
30th Dec, 2006 at 07:32:32pm
30th Dec, 2006 at 07:48:00pm
Auto frames also have the engine mount holes forward of the original position (could be wrong but I think the auto and injection frames are identical).
30th Dec, 2006 at 08:05:22pm
cheers guys |
30th Dec, 2006 at 08:32:34pm
im pretty sure auto subbys are different than all manual ones including injection ones. you can use an auto subby in a manual with the use of a engine mount spacer kit i think. not 100%.
397 Posts Member #: 694 Senior Member Shropshire |
31st Dec, 2006 at 09:33:49am
MiniTurboBadBoy
31st Dec, 2006 at 05:51:49pm
Ok thanks for the advise I was only going to use an injection subframe because one is being solt locally.
31st Dec, 2006 at 06:33:07pm
31st Dec, 2006 at 06:37:33pm
Ive modified the clamp to fit when the engine was out. Its the bracket that goes around the bottom of the downpipe and bolts to the gearbox to hold it steady? |
