Home > Technical Chat > Airflow for the turbo metro?
Lance Link
Member #: 1174
Sunny Southern California, USA
Ok. I'm thinking about having a custom intercooler built for my engine (www.bellintercoolers.com). To do it correctly I need to know the airflow for the turbo 1275.
By my calc the 1275 (78ci appx) motor flows 150 cfm at 6700 rpms given 100% VE. Or is there more to it than that since we are dealing with a turbocharged engine? My thought is that the air volume the motor can ingest is constant at a given rpm. The density of that volume is not. So the turbo should not effect this calc. Does this make sense? Or am I missing something?
I know you guys know a lot more about this than me...so I figured I'd ask!
Edited by Lance Link on 4th Jan, 2007.
61 Austin Seven; building a 1275 'over the clutch' turbo, R5 T2'd, custom intercooled, megajolt electrified, canyon carver
www.motorlust.com - The Online Magazine for Car Guys Like Us
fortfun
Member #: 954
Fort Collins Colorado USA
Your caculation is right on for normally aspirated, and your thinking about volume is right too, but...
All things that flow air are rated for airflow under standard conditions, something like 20C and 1bar absolute pressure. Denser fluid resists flow more. An extreme example is air vs. water.
Intercoolers are sized by the flow under standard conditions. So you need to calculate how much airflow you intend to have when you get done modifying the car. An easy approximation is to use 1.4 CFM per horsepower of output.
1275 with Back Door Turbo
Lance Link
Member #: 1174
Hey fortfun. I know you from the MM forum! I'm known as Cheese~ over there.
Utilizing your 1.4cfm number, and understanding that most 1275's have about 70hp stock, we get a cfm requirement of 98cfm. Thats a lot less than the 150cfm calculation I came up with. Is that because your 1.4cfm/hp number takes into account a volumetric efficiency of less than 100%...ie real world numbers?
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
You need to size for where you want to end up, not where you start .... stock 1275 turbo unit gives around 94 bhp so would need 140ish cfm using 1.4ish
Dont most IC people size their cores based on a rough horsepower goal ??
Lance Link
Member #: 1174
It looks to me like most of the people around here are not doing this. Most of them seem to be choosing their intercoolers based upon what is available at the local scrap yard and what fits.
Edited by Lance Link on 6th Jan, 2007.
Lance Link
Member #: 1174
Sorry. I don't mean to sound thick. What I was outlining in one of my previous posts was that the 1.4cfm/hp guesstimate number didn't seem to match up with an actual airflow calculation for a given motor (in this case a na 1275). And before applying that calculation to my turbo motor, I wanted to understand it better.
fortfun
Member #: 954
Your engine pulling 150CFM would be making 110+ HP. Your 150CFM calculatoin assumed 100% volumetric efficiency, and that is tough to achieve with a naturally aspirated engine with streetable cam and exhaust.
In practice you should be able to significantly oversize the intercooler without fitment problems.
RogerM
Member #: 1217
Some of us do look at the max air-flow, can't see the likes of TD, Jimster, Turbo Tim, Nic etc. just plonking it on because they had it.
It is my opinion that a lot of people use an IC like the one from the Escort RST because it will flow well enough for around 180 BHP which is about what most of the road going cars are going to peak at (assuming it's a daily driver not just a road warrior).
The other popular one I've seen on here is the Cossie IC which is good for around 300 BHP, there aren't that many 300 BHP A series out there so it should be good enough for vertually all.
Finding some of the flow figures for standard ICs is a problem but if you look at the donor cars tunning capability and see the point at which tuners change the IC it will give you a reasonable idea of what BHP you can run with a given IC, after all the air required to provide X BHP is similar for any turbo engine.
About a year ago Robert did some air flow testing of existing intercoolers:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=8573
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=8574
Lance Link
Member #: 1174
Thanks guys. I appreciate the info.
If a person were to install an oversized intercooler, like the cossie one, wouldn't all that excess capacity add to the lag when trying to build boost? Or is it infinitesimal when compared to a smaller, more closely matched intercooler?
It looks like the one I'm speccing out will be capable of flowing 200hp. Since I'm only looking for 130-140hp, it should be ok.
Lance Link
Member #: 1174
As I was suspecting, this would then account for the difference between the calculation methods. Thanks!
I personally think, you would need a HUGE intercooler, for any apparent "lag" to be noticeble.
I dont think it would be physically possible to fit an intercooler so big, that it would become an issue on a mini ( unless you mount it in a silly place lol )
RogerM
Member #: 1217
Roof mounted intercooler anybody ......
LOL
