Home > Help Needed / General Tech Chat > Getting a Bottom Pully Machined Quickly
Anton
Member #: 764
Staffordshire
I need to get a snd 1275 bottom pully machined in the 36-1 tooth arrangement asap.
I know tom does them but its a 4 week wait, and I cant really wait that long. Bud666 tried to get it done at a local place but they wanted 100quid.
any ideas?
You could try one of these out?
http://www.trigger-wheels.com/
Dangerous
Member #: 417
I got one off Toms ones you can Borrow,As I have no bracket yet.
Dicanio
Member #: 91
I've made a similar offer on your wanted thread a few days ago
I bolted an Omex generic wheel to the standard pulley.
I used the two bolt holes already in the crank pulley with two spacers I knocked up. MPC in Walsall usually have the wheel in stock....
Anton
Member #: 764
Staffordshire
any pic's bat?
Now there's a thing.... I'll take some in the morning.
Please be aware it's a very lo tech affair *wink*
Doh!
Edited by Bat on 6th Jan, 2007.
Nick
Member #: 154
Midlands
i was up at MPC today, getting fleeced for a change.
No doubt. But if I remember correctly they're about £30, although that was 2 years ago! Long before Toms pulleys were available.
When I do it again I'll be using one of Tom's, if it'll be possible on an MPi pulley...
t3gav
Member #: 229
Gavin@minispares.com
kent
Correct me if i'm wrong but there are not 1 but 2 people offering you their pulleys, you couldn't get a better response than that, what a good forum eh :)
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Its not possible on a mpi pulley IMO.
Alex
AlexF
Alex .. Probably, but I'll send it to Tom and see what he can do....
Gav .. I don't know why the offers haven't been taken up, so I thought i'd post up what I did *wink*
Please don't ask for dimensions as I've not got any, due to the use of make it up as you go engineering.
Basically Make up spacers and bolt wheel to the two holes as shown in the pulley photo.
Weld bracket to the steel bracket the engine mount bolts to. You may also need to modify the lower rad braket to give a little extra clearance. *wink*
I'd recommend drilling some large holes in the wheel to reduce it's weight / inertia.
Edited by Bat on 7th Jan, 2007.
Anton
Member #: 764
Staffordshire
thanks all.. expecially for the offers of a loan pullys.. your right this forum rocks!
luckily im sorted.. or should i say i will be when it arrives. many thanks to tom fenton who's managed to sorte me a pully out.
