| Home > Help Needed / General Tech Chat > Exhaust elbow mods | |||||||
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
29th Jan, 2007 at 01:36:10pm
Reading the archive this seems to be an important issue,but cant find any detail on what to do to improve flow on a cast elbow.Any pointers? 'Where does the engine go?' |
29th Jan, 2007 at 01:49:57pm
benross did mine (plus many others) and the work is tip top.
29th Jan, 2007 at 03:10:40pm
basically increase the diameter and flow it as per an exhaust port |
29th Jan, 2007 at 03:28:30pm
mine's standard and goes well enough. then again its not staying on as i will be going T2 again |
29th Jan, 2007 at 03:46:16pm
every little helps |
809 Posts Member #: 224 Post Whore Katy TEXAS |
29th Jan, 2007 at 04:36:55pm
Benross did mine to, what a guy, the manifold needs work to Edited by Brocky on 29th Jan, 2007. BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
29th Jan, 2007 at 05:29:13pm
He did mine this weekend and the workman ship is shit hot. Plus hes a dead right bloke. Hes got plenty on at mo though. Or you could have a pop at it yourself! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
![]() 1014 Posts Member #: 238 Post Whore essex |
29th Jan, 2007 at 06:58:23pm
benross also did mine, and as others have already said the work is top class.. ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
29th Jan, 2007 at 09:59:31pm
Is there any improvment that can be made on the mirrage elbow, or are these reasonably well flowing?
29th Jan, 2007 at 11:06:23pm
you cant really do anything as its only made from SS tube. nothing to grind out!! |
30th Jan, 2007 at 06:15:40pm
I have done My manifold and Elbow, using a oval shape carbide burr seem to do the trick quite well! |
