| Home > Help Needed / General Tech Chat > OT - Ford Focus - Now on Engine No.3 | |||||||
3rd Feb, 2007 at 10:06:42am
My old man has been having problems with his Focus (only started two days ago, it was running fine until then) basically it runs as rough as a bag of badgers and when you put you foot down it coughs and splutters before the revs slowly increase. I've looked for the obvious loose connectors and split hoses but I can't see anything, we've also replaced the spark plugs but no joy there. It was in the garage yesterday, but they've not found anything either, so I'm open to suggestions.
Edited by Rob H on 21st Sep, 2007. Isambard Kingdom Brunel said:
3rd Feb, 2007 at 10:17:27am
What's the engine?
3rd Feb, 2007 at 05:47:46pm
Kid i know has a Mondeo that was doing the same thing (it also towed to start sometimes), He said it was the crank sensor that was loose or broken! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
3rd Feb, 2007 at 06:00:12pm
Edited by Bat on 3rd Feb, 2007. VEMs Authorised Installer / Re-seller. K head kits now available!
3rd Feb, 2007 at 07:03:29pm
Heres all the fault codes
784 Posts Member #: 912 Post Whore North Yorkshire |
4th Feb, 2007 at 08:19:10am
The plug lead sets on these can and do break down. And start to earth out down the plugs. Especially under load.
I drill holes in everything..! |
4th Feb, 2007 at 09:50:11am
Cheers guys, the engine is nothing fancy just the 1.6 zetec. I fitted new leads yesterday and whilst it runs smoother it still bogs down when you open the throttle, I'm wandering if it could be the map sensor maybe?
4th Feb, 2007 at 02:21:44pm
make it splutter and then shut the engien off and check the plugs, do they look like ther egoing lean? it "sounds" like a fueling prob but obviously its impossible to tell without the car infront of me.
4th Feb, 2007 at 07:29:01pm
Possible coolant temp sensor failure. Equivalent to driving with the choke on all the time.
5th Feb, 2007 at 09:52:45am
have you checked the fault codes? The link that dangerous gave you shows you how todo it. Team www.sheepspeed.com Racing
17th Feb, 2007 at 09:26:39am
Turned out to be a combination of crank sensor and coil pack on the way out. The garage reckon the failing crank sensor lead to the damage to the coil, I can't quiet see how, but if they're right it could be something to bear in mind when setting up MJ installs. Isambard Kingdom Brunel said:
18th Feb, 2007 at 12:51:32pm
Rob ... glad you got that fixed but I have another question .....
18th Feb, 2007 at 09:47:13pm
I came across the picture of you're dog whilst I was looking for pictures of Mr Woo, and it made me laugh, so I made it my avatar. If you want you can have a picture of Patch for you're avatar. Isambard Kingdom Brunel said:
9th May, 2007 at 11:00:27pm
On 17th of Feb, 2007 at 09:26am British Open Classic said:
Turned out to be a combination of crank sensor and coil pack on the way out. The garage reckon the failing crank sensor lead to the damage to the coil, I can't quiet see how, but if they're right it could be something to bear in mind when setting up MJ installs. How wrong we were. It's got worse and worse over the last few month and total died trying to get up a hill last week. Ford took the head off and a chunk of piston was missing, so it's going to be a new engine, cheaper than repairing it (and not sure if we trust Ford to fix it after there previous diagnosis). So does anyone have any advise with regards to running in a Zetec? in terms of choice of oil, how often it needs changing and what to see the the rev limit at? Isambard Kingdom Brunel said:
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
10th May, 2007 at 09:38:18am
how old is the car? are you having to fund the new engine or are they paying? Do you know how the piston got damaged? |
197 Posts Member #: 1488 Advanced Member Bristol |
10th May, 2007 at 05:41:48pm
Ouchies, sorry to hear that mate :( If you need anything I've got some rather tenuous contacts with Brunel Ford- I need a wing mirror off them anyways after a run in with some chavs :( There is no sense crying over every mistake- you just keep on trying til you run out of cake. |
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
10th May, 2007 at 06:03:10pm
I would be looking into how the piston was damaged tbh! I've seen the future and tbh its Pie
19th May, 2007 at 11:04:11pm
The car is that awkward age where the warranty is no more but it's still worth replacing the engine as opposed to writing the car off.
22nd May, 2007 at 06:20:57am
My have to say my focus now has 110000 miles on the clock and (touch wood) is still running sweet as a nut! There is no sense crying over every mistake- you just keep on trying til you run out of cake. |
21st Sep, 2007 at 11:17:51pm
Major up date - Now on engine no. 3
122 Posts Member #: 1812 Advanced Member Live in birmingham and work sheffield |
21st Sep, 2007 at 11:30:48pm
stupid question but have they changed the temp gauge/cluster?
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
21st Sep, 2007 at 11:33:47pm
sounds more likely to be a wiring fault than mechanical. something must be intermittently triggering the limp home mode On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
21st Sep, 2007 at 11:35:26pm
but on a focus it would put the management light on and leave a fault code
22nd Sep, 2007 at 12:15:47am
fair dos mikey. you're the one worked for ford anyways lol On 23rd Oct, 2009 sim_ou_nao said:
22nd Sep, 2007 at 08:23:50am
