Home > Help Needed / General Tech Chat > Inlet maifold
liles999
Member #: 1417
Bridgend
I have a small crack in the heater pipe (the one which curls back up over the manifold) on my turbo engine.
Can this be swapped for a non turbo water heated cooper manifold or is it different?
My other alternative is to cut this pipe a little shorter as my mini heater pipe will be able to reach.
Your thoughts please
just bypass the pipe.
all it really does is heat up the intake air slightly, not really what you want on a turbo motor.
Edited by Joe C on 6th Feb, 2007.
Or weld it up
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
It does heat the manifold yes but you may want that on a turbo Mini, but only if it's a daily driver and running low boost!
Turbo manifold is taller than any other SU manifold I have come across to clear the turbo by a sensible margin.
liles999
Member #: 1417
Bridgend
I could weld it but it's on the bend and I'm not the best at welding.
But I could cut it off just before the bend?
"Turbo manifold is taller than any other SU manifold I have come across to clear the turbo by a sensible margin."
So my manifold from my n/a engine will not fit?
"It does heat the manifold yes but you may want that on a turbo Mini, but only if it's a daily driver and running low boost! "
Does this mean that in order to run more boost I will need to change my manifold?
RogerM
Member #: 1217
You don't need to change the manifold for more boost. If your going to push the boost up a fair bit it'll be best to take the manifold out of the coolant circuit.
my advice is to cut it off before the bend i have done this no problems
and may be extend the rubber hose a little
i would run the rad coolent through this as it helps the back pocket on economy and if you intend to run silly boost figures in the future
british leyland got this manifold just right for the turbo engine
(keep it) its hard to beat if at all................*wink*
Edited by BENROSS on 6th Feb, 2007.
liles999
Member #: 1417
Bridgend
Cheers. I will get out the trusty hack saw then.
metroturbo
Member #: 989
North Yorkshire
Wouldn't the coolant flow also help to keep the manifold cool when the car is sat in traffic?
JT
Member #: 637
Hertfordshire
it depends if you run a intercooler or not.
im sure iv read in a post not that long ago that if you have a intercooler, the water would heat it all, but if you dont run a intercooler, then it would cool it.
hope that makes sence!?
cheers
josh
My build thread..
in generall leave it plumbed up as its supposed to be
this means Extra! miles per gallon for the back pocket
there are many whys and wherefors about this!
In winter it's essential, more so if you've got an intercooler fitted.
My current manifold has no provision for heating, so once the carb ices up it runs rougher than a bears arse (aledgedly.)
If you park it up for 15 mins and let ice melt it'll be ok after.
JT
Member #: 637
Hertfordshire
what about performance though steve? *evil*
My build thread..
performance will be enchanced for only a few minuits if you dont couple the manifold up
then the under bonnet temps will quickley rise effecting, reducing fuel octane to a few points less
this inturn has a marked effect on the boost you run reducing it by some 2 to 3 psi before detanation sets in (less power) *frown*
this case is helped some what by the fitment of a 74deg thermostat,
the engine all runs nice at this temp canceling out, the under bonnet temps in the manifold allowing higher fuel octane not to be reduced throug hot spots if the manifold is plumbed up
some may argue but.......... this is the case!
RogerM
Member #: 1217
Benross's experiences match my own. If it's a daily driver or indeed any sort of road car fit an IC to look after a boost and connect up to the water so that you can get a bit better economy for when it's off boost .... which to be fair is probably most of the time and maybe keep it from icing in the chilly months!!!
I still am of the opinion that for a big banana race motor there is no real need or advantage to running heating on the manifold.
Having said that the shear volume through-put of charge going into a high power lump at high revs means it's never going to be in the manifold for long enough to really get heated so there is probably no real disadvantage either..
Like so much in tunning it's a compromise and all down to what you want from the finished package.
Edited by RogerM on 7th Feb, 2007.
you put it spot on roger
