| Home > General Chat > clutch & gearbox's do you paint or just clean them up!!! | |||||||
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
18th Feb, 2007 at 01:09:02pm
just after what most of you guys do, do you clean up & paint the gearbox & clutch housings or just clean them up with a wire brush on a drill & leave as is
18th Feb, 2007 at 04:26:44pm
i use alloy wheel acid to clean the aluminium bits. no longer a series, but still 1.3 turbo.
18th Feb, 2007 at 04:29:19pm
jet wash before stripping the engine apart gets 90% of the crap off "Turbo's make torque, and torque makes fun"
18th Feb, 2007 at 04:44:09pm
all has been soaked in degreaser & jetwashed & i'll probobly attack the parts with a wire brush on my drill, but want it to look tidy when i'm all finished, i just dont want to paint parts then for it to flake as i've seen happen on other engines, its a shame if you put the effort to building a new motor & make it look all spangly for it to look shit cause of flaky paint, i'd be so gutted SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
18th Feb, 2007 at 06:04:15pm
Use acid etch primer first On 26th Oct, 2004 TurboDave16v said:
18th Feb, 2007 at 06:09:22pm
i dont toiuch the box just give it a clean but i paint the trns fer and bell housing with thined down smoothrite and use my spray gun.
18th Feb, 2007 at 06:37:54pm
I used a can of carb cleaner spray to clean the gearbox casing on mine. Got it really new and shiney looking. |
18th Feb, 2007 at 06:57:08pm
paint the engine block and head
18th Feb, 2007 at 07:09:02pm
the ally box & transfer casings dont seem to be painted as standard from the factory, thats the other reason i was a lil jubious about painting them, i've never had ally take paint to well myself, if i went to a fine-ish grade with scotchbrite wheels it should look standard should'nt it SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
18th Feb, 2007 at 07:23:41pm
Give it some "Go faster" Green.
18th Feb, 2007 at 08:16:09pm
Personally I don't like to see the castings painted, the machine shop I use has a good acid clen bath which leaves most things looking pretty clean anyway, once they have had a gose dose of jetwashing afterwards.
18th Feb, 2007 at 09:08:51pm
how would you go about getting paint off the gearbox housing? as the one have is already painted in green, which i dont rely want! My build thread..
18th Feb, 2007 at 09:23:30pm
Paint stripper......
18th Feb, 2007 at 09:24:23pm
i'll do some pics of this progress on my housings this week as i'm doing these before the gearbox, they are going to get another dose of degreaser & jetwashing tomorrow & i'll make a start with the wire brush in a drill, slightly off topic but still with the housings,
18th Feb, 2007 at 11:37:57pm
i wouldnt risk wire brushing the ally, it will leave a 'scoured' finish.
784 Posts Member #: 912 Post Whore North Yorkshire |
18th Feb, 2007 at 11:46:34pm
Mr Muscle Oven cleaner works pretty well. And is cheaper than engine Gunk to. I drill holes in everything..! |
19th Feb, 2007 at 01:08:24am
It's ok to use wire bushes so long as they are the crimp type not notted ones. Helps if you take a large does of subtlety with breakfast.
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
19th Feb, 2007 at 09:32:01am
My box was painted blue (looked awfull) before I sent it off to turbohogster to be referbed I went at it with a wire wheel, then jet washed it, came up a treat.
180 Posts Member #: 591 Advanced Member Rugeley, Midlands, England |
19th Feb, 2007 at 10:11:16pm
I used nitromorse paint stripper to remove the layers of rainbow pain it had been painted in, then masked up all flat ground areas and glass blasted polished degreased and given a coat of clear heat resistant varnish result looks good. |
25th Feb, 2007 at 03:55:09pm
Sorry its taken all week to post these pics, only got the parts back on fri from bead blasting
25th Feb, 2007 at 07:55:57pm
that looks pretty smart in blasted & painted, a real decent finish there shaneyboy! SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
26th Feb, 2007 at 11:16:41pm
Thanks, my local powder coaters are the nuts and very helpfull with what ive asked from them. Its looks ok in the pics, as you cant cee the runs in my pi** poor painting skills, but luckily they will hiden at the back of the bay!
![]() 184 Posts Member #: 346 Advanced Member Portsmouth |
18th May, 2009 at 07:21:13pm
Sorry for digging up an old thread, the left hand pic of the clutch cover above, is that the finish after sand blasing and zinc coating? 1310cc TWINK - T Conversion |
628 Posts Member #: 1064 Formally Whyte_ben Horndean, Hampshire |
18th May, 2009 at 08:39:50pm
Just sand blasting it looks like.
