| Home > General Chat > trigger wheel and VR sensor position | |||||||
![]() 243 Posts Member #: 89 Senior Member Sydney Australia |
20th Feb, 2007 at 01:57:47am
Hi Guys,
179hp on 12psi 1293cc of pure A series
20th Feb, 2007 at 02:01:18am
Edited by Turbo Tel on 20th Feb, 2007. website:- http://www.terryhunt.co.uk
20th Feb, 2007 at 02:18:14am
OK
20th Feb, 2007 at 07:11:58am
Yep, keyway is at TDC, line missing tooth up with the keyway to make life easy.
18 Posts Member #: 1067 Member |
20th Feb, 2007 at 11:08:28am
I guess you're using a home-brew trigger wheel such as one of trigger-wheels or a sierra job, rather than one of Tom Fentons?
20th Feb, 2007 at 07:05:10pm
Set the engine to TDC, the missing tooth at 12 and the sensor at 9. |
20th Feb, 2007 at 07:34:32pm
On 20th of Feb, 2007 at 07:05pm MarkGTT said:
Set the engine to TDC, the missing tooth at 12 and the sensor at 9. this is far the easiest way and a simple bracket can be made. but in thereo you could moubt the sensor anywhere you want so long as its 90 degrees before the the missing tooth at tdc. i.e missing tooth at 12 sensor at 9 or missing tooth at 3 sensor at 12 etc. the important thing is set it with engine at tdc. heres a pic of mine please assume the engines at tdc and the missing tooth is at 12 oclock.(typicaly the pic i took the engine wernt at tdc, lol) my bracket my look a little rough but its adjustable. i elongated the holes in it then the bracket is sandwiched between the rad mount.
Edited by Carl on 20th Feb, 2007. no longer a series, but still 1.3 turbo.
21st Feb, 2007 at 12:56:51am
21st Feb, 2007 at 01:32:16am
thanks heaps guys i really appreciate it.
21st Feb, 2007 at 07:48:34pm
On 21st of Feb, 2007 at 12:56am Turbo Tel said:
I like that Bracket Carl!! It looks really easy to make and as you say easily adjustable for distance. How do you adjust the vertical position? or is is near enough that you can adjust the map accordingly? Terry i worked the bracket so its in the exact persistion and just need adjustment left to right for the air gap. its spot on so i dont need to allow for differences in the map. no longer a series, but still 1.3 turbo.
22nd Feb, 2007 at 04:37:52am
22nd Feb, 2007 at 10:41:56am
I have a mini-pulleys wheel and bracket so i'm hoping it should be at 90 degrees already yes? |
27th Mar, 2007 at 01:17:30pm
Hi all,
27th Mar, 2007 at 02:38:33pm
Here is my sensor bracket
27th Mar, 2007 at 07:47:45pm
Here's mine:
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
28th Mar, 2007 at 11:25:28pm
Bassed mine on a few I've seen on here, tooth on pully at tdc, and sensor at 90oC before.
Edited by shane on 28th Mar, 2007. |
