| Home > Help Needed / General Tech Chat > Brake servo | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
20th Feb, 2007 at 12:10:21pm
I have a brake servo sitting at home next to the car, i have the pipe and the diffrent brake pedal which seems to be needed to fit it all to my mini, but should i? I have metro turbo brakes on the front and standerd drums on the back got about 110bhp so its not hanging around. Some people seem to thing there wicked and i should fit it and some say theres no point. Lets opened it up. Servo or no servo? |
809 Posts Member #: 224 Post Whore Katy TEXAS |
20th Feb, 2007 at 12:49:23pm
Personally I have never run a servo in a mini,
20th Feb, 2007 at 12:57:13pm
For a road car yes. The feel isn't much different as far as I can tell and it takes much less effort on the pedal.
20th Feb, 2007 at 12:57:48pm
Bin it!
20th Feb, 2007 at 12:59:19pm
are you sure you have turbo brakes? not just late metro brakes?
20th Feb, 2007 at 01:12:20pm
Seems even so far 2 for and 2 against. At the moment i can spare the engine bayspace. The car will do the odd track day and nice summer driving as i have a Mx5 for winter times (hardtop stays on all year) but the extra waight won't make to much odds. but if all it will do is make the peddel lighter there not much point, i want to improve brakeing not just make it easier. |
20th Feb, 2007 at 01:47:43pm
I have a break servo in both my minis and think they're great :) |
20th Feb, 2007 at 02:27:06pm
try without a servo, then when you get pissed off with crap brakes you can fit the servo. it wont make the braking any better BUT atleast when you press them hard compaired to modern cars they will slow you down.
20th Feb, 2007 at 02:47:45pm
thats a good argument for. No i don't use the mini every day i have become weak and pittiful and i bet once i get back in the car i will remmeber how heavy the wheel is and how hard the clutch feels and the momentus power needed to stop the blasted thing. the Mx5 at least doesn't have powersteering but think my legs mite get a shock driving the mini again. Thanks
20th Feb, 2007 at 06:33:01pm
I personaly dont think that it makes the pedal lighter On 26th Oct, 2004 TurboDave16v said:
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
20th Feb, 2007 at 06:59:30pm
the whole point of a servo is to add more pressure to what you put on t the brake pedal, so less effort is needed by you to make your car stop "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
20th Feb, 2007 at 07:03:25pm
good point, but the pedal travels less. Your satement does not explain this On 26th Oct, 2004 TurboDave16v said:
282 Posts Member #: 1404 Senior Member The Netherlands |
20th Feb, 2007 at 08:51:28pm
servo works perfectly, but it's a enormous peace off metal unter the bonnet. i binning mine soon.
Edited by paneermeel on 20th Feb, 2007. there is nothing wrong with a A-series that a turbo can't fix.
54 Posts Member #: 1425 Advanced Member Yorkshire Wolds |
20th Feb, 2007 at 09:49:44pm
I replaced the standard tandem brake master cylinder for a later type pedal box servo and TBH I was a little dissapointed with the servo. Main reason for the change was to get a lighter pedal, since using 7.5inch S discs with 4 pot calipers resulting with a very hard pedal resulting in leg ache after a days driving. Personally I wouldnt bother fitting it. Now I cant be arsed to swop it all back, however if your like me you proabably like finding out for yourself! |
20th Feb, 2007 at 09:53:44pm
lol. yep, i need somthing to do and i have 3 days at the end of april to get the car out the garage and in to fighting roadgoing status. so i'll do it then.
20th Feb, 2007 at 09:56:09pm
Nice one! Gunsons Easybleed to the ready! |
20th Feb, 2007 at 10:08:55pm
as i dont have a servo/pedal box to look at i would guess that the leverage points have changed, so less pedal movement is needed to exert the same amount of force, master cylinders a different maybe "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
20th Feb, 2007 at 10:53:07pm
yep easy bleed is standing by and i think i mite push the boat out and use dot 5.1.
22nd Feb, 2007 at 06:53:03am
alrighty! |
22nd Feb, 2007 at 01:04:13pm
On 20th of Feb, 2007 at 12:59pm Turbo Shed said:
are you sure you have turbo brakes? not just late metro brakes? What's the difference? I always thought they were the same thing.
22nd Feb, 2007 at 01:32:20pm
I thought the turbo ones were 4 pots with vented discs. the later ones didn't have the vented disc so need a spacer to fit them discs. |
22nd Feb, 2007 at 01:34:01pm
waste of your 3 days i'd say... |
22nd Feb, 2007 at 01:42:29pm
turbo brakes and late metro brakes are the same. it just gets me that people sell them as "turbo Brakes" when there actually off a 998 metro city. like people sell "genuine turbo cam shaft" rather than put standard 1275 cam. after all, if say 1 million metros came with vented discs and say 5,000 were metro turbos, then shorly they should be called standard metro brakes and not try and claim there something special |
22nd Feb, 2007 at 01:49:45pm
I agree |
24th Feb, 2007 at 01:36:11pm
When I built my NA Mini I started with a Racing Green which had a servo as standard so I kept it.
