Home > Technical Chat > belt drive every 20,000
Mark1275GT
Member #: 886
London.
Is it true that you should change your belt drive every 20,000 miles ?
Its done 7000 over 6 years i guess.
If you think i should change it.
is it a easy job, what would i need etc to do timing which ive heard you have to do..
And how would i know what belt to get for my metro turbo engine.
Plus, when i took the case off, it had some oil on the inside. not loads, just abit. is that normal...
Thanks for ya help///*smiley*
Had one for 12 years never changed the belt. If you've got as far as taking the cover off, you've nearly done it!
Line the dots up on the pulleys, slide off old belt slide on new one.
As far as I know there's only one belt. Bit of oil won't hurt as long as the belt is dry *wink*
Mark1275GT
Member #: 886
London.
Cool..
So you dont have to do some sort of timing when u put the new one on.. plus, how would i know what belt to get...thanks alot..
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I change mine every year!
short belts wear badly.
Alex
AlexF
Just make sure the dots are lined up. Just get a belt from your favourite Mini parts supplier *wink*
Or http://www.minispares.com/Product.aspx?pid=34651
Mark1275GT
Member #: 886
London.
Cool thanks for that.
So how do i make the the dots line up.
Can i turn the pulleys by hand ? thanks :)
Line them up before you take the old belt off!
Put it in 4th gear and push the car until they line up.
nogin
Member #: 487
westbury, wiltshire
you should change it every 5 years at the latest or erlier if only used for short jurneys or has very little use, rubber degrades with age as it is only a natural substance
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
Mark1275GT
Member #: 886
London.
Is there anyother way to line the dots up. as theres cars either side of me.. thanks
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
turn the crank!!!
Alex
AlexF
miniminor63
Member #: 672
The oversills police
Oslo, Norway
Is it not possible just to take the old of, and the new one without turning anything, it should be like before then?
i'd just mark it up as it was on both pulleys with something like tippex and then change it. the markings are only needed to re-align if somethings moves. be careful and you'll be fine *smiley*
