Home > Help Needed / General Tech Chat > What's a Good Lubricant to use when Assembling Piston Rings
What's a Good Lubricant to use when Assembling Piston Rings?
I guess they need a bit of oil, for the first start up. I was thinking WD40.
Brocky
Member #: 224
Katy TEXAS
Would use the oil you intend to run in the engine or a good quality engine builders oil ?
Edited by Brocky on 6th Mar, 2007.
i use engine oil if its going to be runnig soon , or hypoy gear oil if its going to sit for a while .
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
engine oil :)
Some people pack a little grease in there if its going to sit around a while and its unlikely to get primed properly before use.
Alex
AlexF
engine oil but i know a bloke who builds F2 pintos who uses WD40
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
I've always used a 20w50 oil or some grease if it's going to sit ... never had any problems
No Comment *wink*
Especialy on the grease *tongue*
Turbo Tel
Member #: 588
Delaware, USA
I always have a nice clean coffee tin at hand 1/2 full of 20/50 and "dunk" the piston before installing it.
Terry
Doodmeister
Member #: 149
Alberta, Canada
I personally wipe bore with a paper towel dipped in oil and get a squirt from the oil can to the rings and piston skirt.
If you don't oil the bore you take the chance of scuffing a new set of rings in a dry bore..
Each to their own i guess.
Leonard
Member #: 806
Cirencester, Gloucestershire
I used 20w50 and have no probs. i also put a squirt in each spark plug hole just b4 i started up
Mirage
Member #: 119
WD40 !
I find Mr Sheen does the trick !! lol
