Home > Help Needed / General Tech Chat > No space for clutch master cilinder on LHD
Popeye
Member #: 262
Netherlands
Hi there,
Ive fitted the complete metro brake setup (dual line) into my engine bay but after shoe-horning my engine in there is not enough space for my clutch master cilinder *frown* .
I m thinking about converting my peddle box to something like ive seen here to make some room http://www.16vminishop.co.uk/popup_image.php?pID=51
but then for clutch instead of brakes.
How ar you guys adressing this problem with LHD mini's? What clutch master cilinders are you using?
Bas
Op de bank beleef je geen avonturen
paneermeel
Member #: 1404
The Netherlands
i'm not so far but i also was wondering if it would fit, see Beginners Tech > Turbo box pictures *happy*
it can be done but i guess that you already got the box welded in and perhapes pianted.
can't you tilted the engine slightly forward to get some room.
if not, i sure like you solution *tongue*
there is nothing wrong with a A-series that a turbo can't fix.
www.turbomini.nl
This guy is a leftie *wink* Take a look at his solution....
http://www.geocities.com/jharkola/1380turbo5.html
If that approach is possible in your situation?
slightly o/t but we had to do a similar think fir brakes in my mates suzuki swift when he put tb's on.
not very clear i know, but we modified a mk2 (?) fiesta setup, they use this thing as std for the brakes.
Yea Ive seen that setup used that Joe mentions once in place worked with no problems (wasn't in a mini, but principle is the same)!
