Home > Technical Chat > intercooler obstruction
Lone Wolf
Member #: 1092
Yours from the Funny Farm
hi
will putting my intercooler behind my front mounted rad obsruct it in any way?
behind as in right up against prolly touching
thanks
tom
Warning:Stig in Training
The Turbocharger:God's Finest Minute
The problem will be your now drawing the hot air from the radiator across the intercooler.
That'll probably heat up the charge air instead of cooling it!
In the 'sandwich' setup the intercooler is always first to 'see' the cool air with the rad behind it.
Edited by Bat on 16th Mar, 2007.
JT
Member #: 637
Hertfordshire
i would put it in front as it will be getting cool air rather than hoter air as its just gone throught the hot cores of the rad.
any pics of what you have planned?
edit, bat beat me to it LOL
Edited by JT on 16th Mar, 2007.
My build thread..
Lone Wolf
Member #: 1092
no no pics josh
just scheming
i was thinking of having the rad out front with electric fan/s on its front and the intercooler and oil cooler behind it,to save space and give the i/c and o/c the benefit of having the fan to cool them at low speeds but evidentely it wont work
oh well it was a though though
Lone Wolf
Member #: 1092
seriously thinking of going to a side mounted rad again
this is as a last resort but if i do so what rads are you guys using?
There's nothing stopping you putting the fans on the front of the intercooler with the rad behind. There's a kit like this for Escort RS Turbos....
Turbo Tel
Member #: 588
Delaware, USA
In Triumphs they always mounted the oil cooler in front of the Rad, Its Important not to leave any space between the two because the turbulant air in the space can case problems, probably no room for a space in a mini but good advice if you go that way..
Lone Wolf
Member #: 1092
hmm thats a good idea bat but an I/C is infinetley more expensive than an old skoda rad i got for free
ill have to think carefully about it cos the slightest bump and the I/C is ruined
You could do a similar setup to an R5 with the rad on one side and the cooler next to it?
Lone Wolf
Member #: 1092
any pics matty?
anyway
if you guys are running stoopid bhp with side mounted rads i shouldnt have any probs right?
so what rads do you guys use?
2 cores?
I use the Minispares 2 core. 16psi and no probs. Plenty of others run more boost with side rads. Just look at MW. *smiley*
Lone Wolf
Member #: 1092
i just realised that
either that rad is very good or the water in it is holy or something
lol
