Home > Technical Chat > Brake discs
mic
Member #: 1271
is it worth changing plain ones to the ones of a
grooved, drilled, vented (in any particular order, doesnt have to be all 3) variety?
8.4" setup for 12"
mic
www.retromods.co.uk
A grooved disc will clean the pad of any glaze, which can help braking if they tend to get very hot.
Other than that no.
Paul
Other than that no.
Paul
Sorry Paul i must disagree , grooved disks are worth between 4 and 6 hp extra in the pub,lol, they are deffinatly on my shopping list.
Carl, sir, I am very sorry that I gave the wrong answer. You are obviously correct. innit.
Paul
I can't believe no one has mentioned the obvious huge weight saving by cutting grooves and holes in the disks.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Bat ..... are you mad ..... look how much heavier vented ones are and the amount of air in them ..... must be heavy stuff air ... LOL
I like grooved disks if I am going for anything on a road car as they are less aggressive on the pads than drilled .... but I have found drilled to be more effective at keeping the pads deglazed and the gasses away from the braking surface.
Vented disks are of use if you are having problems with fade but would probably not fit them as a matter of course for a road car. 4 pot calipers however are a must IMHO ..... manily due to the increased pad area.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I felt that my grooved discs lasted a little longer, but they are supposed to be a higher spec material aswell so who knows. I would love some four pots but I can't get them behind my reverse rims that easily. I don't fancy using a 9mm spacer to be honest.
On 7th Nov, 2008 Nic said:
naeJ
m
RogerM
Member #: 1217
Jay add 3" and get proper sized wheels *wink*
i have pagid 40 groove they seem ok
Jay#2
Member #: 648
Eh no I love my reverse rims!
naeJ
m
